Windshield Gaskets- Who Makes the best one #2407552
11/22/17 08:38 PM
11/22/17 08:38 PM
KY
65pacecar Offline OP
KY
I need a new windshield gasket for a 65 Sport Fury, who makes the best out there, or are they all the same?
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407606
11/22/17 11:03 PM
11/22/17 11:03 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Precision or Steele are your two choices. We sell both and for that application. In my opinion the Precision gasket will work fine for a significantly lower price.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407623
11/22/17 11:47 PM
11/22/17 11:47 PM
KY
KY
Thank you do you have it for a convertible.
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407654
11/23/17 12:51 AM
11/23/17 12:51 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
For that particular application, both the hardtop and convertible uses the same gasket. So it would be a matter of your personal preference for which gasket manufacture or vendor you should decide to use. If you should go to each manufacture's web site and compare pricing from each, you will see that there is approximately a $100 difference in the pricing. Whichever one you should decide to go with, should fit and function fine.
On some applications, I know that one brand may fit a bit better or that one brand may be purchasing from the other manufacture to provide coverage. For this particular gasket, each one is their own gasket.
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407671
11/23/17 01:17 AM
11/23/17 01:17 AM
KY
KY
Thanks. I thought HT and Convertible was the same gasket. I'll be giving you a call. Fir this application do you see any benefit if going with Steele over Precision? I sm not familiar with Precision but it sounds like it may be a good option.
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407677
11/23/17 01:26 AM
11/23/17 01:26 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
For some applications, there are absolute advantages of using one over the other. But in your case, I would not hesitate in going with the cheaper gasket. For some people, they would much rather go with Steele as most of their products are manufactured in North Carolina. The Precision gaskets are usually manufactured in Thailand or India. Precision is an OEM vendor to the automotive industry and is involved in a variety of other industries as well.
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407681
11/23/17 01:32 AM
11/23/17 01:32 AM
KY
KY
Thanks for the help.
Re: Windshield Gaskets- Who Makes the best one [Re: 65pacecar] #2407795
11/23/17 12:36 PM
11/23/17 12:36 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Glad to be of assistance, I have sent you a private message.
