Valve cover breather backward valve = no PCV? #2405580
11/18/17 07:08 PM
11/18/17 07:08 PM
Rancho Cordova, Calif.
davidcwhitney Offline OP
1976 440-3 with smog eqpt and no cat. I have oil blowing out the dipstick. I took off the breather hose (passenger side) and sucked on the tube -- nothing. Took out the fitting and sucked on the tube -- just fine.
Also checked PCV valve (driver's side) and for any obstruction in the hoses. All good. I just passed smog and no cylinder appears to have blowby past the rings.
The question is if this could be the sole reason for lack of positive crankcase ventilation or if I should keep on looking.
Edit: Stupid rookie mistake. The parts store sold me a "breather" cap with a valve that only allows air out and allows no air in. Duh.
1977 Executive Diplomat II
Re: Valve cover breather backward valve = no PCV? [Re: davidcwhitney] #2405708
11/18/17 11:26 PM
11/18/17 11:26 PM
Dave it is always a good day when you can solve an issue yourself with minimal work. (enjoy it while it lasts!).
Re: Valve cover breather backward valve = no PCV? [Re: davidcwhitney] #2406079
11/19/17 09:39 PM
11/19/17 09:39 PM
Put in a proper breather. No more oil out the dipstick!
Re: Valve cover breather backward valve = no PCV? [Re: davidcwhitney] #2406253
11/20/17 09:48 AM
11/20/17 09:48 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Stupid rookie question, how can you tell if a breather is one way or two way?
Re: Valve cover breather backward valve = no PCV? [Re: MI_Custumz] #2406256
11/20/17 09:55 AM
11/20/17 09:55 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
