Small block LA rear main seal #2404643
11/16/17 10:14 PM
11/16/17 10:14 PM
CA.
RAY1969CARS Offline OP
CA.
Hi guys I was wondering if everyone offset the seal 3/8 of an inch like it says in the How to rebuild a small block Mopar engine hp books
Please walk me through all your tips and tricks thank you
Re: Small block LA rear main seal [Re: RAY1969CARS] #2405185
11/17/17 09:20 PM
11/17/17 09:20 PM
IN
schmitty Offline
schmitty  Offline
IN
Hi Ray,
I offset mine the 3/8 or so. High quality rtv - right stuff on ends and a little bead on the each side.
Re: Small block LA rear main seal [Re: RAY1969CARS] #2405229
11/17/17 11:37 PM
11/17/17 11:37 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I dont offset them ..just put a dap of rtv where they connect.
Tony
70 AARCuda Vitamin C
Re: Small block LA rear main seal [Re: RAY1969CARS] #2405579
11/18/17 07:08 PM
11/18/17 07:08 PM
crlush Offline
crlush  Offline
No offset for me
Re: Small block LA rear main seal [Re: crlush] #2405710
11/18/17 11:30 PM
11/18/17 11:30 PM
I offset one once & it leaked but I very well may have done something wrong. Agreed on a very small drop of sealant on the ends where the ends meet. I like to use some real thin sealant around the OD of the seal itself, permatex 99MA "high tack", is is a very thin tacky spray sealant/glue so I'm very carefull on how I apply it as to not get any of it where it don't belong.
Re: Small block LA rear main seal [Re: 70AARcuda] #2405944
11/19/17 03:09 PM
11/19/17 03:09 PM
iagree I do that on all of the ones I do, especially with the ones that have the tang on the upper or lower(CRS which one has them realcrazy) part up
