W2 Head questions. #2404201
11/15/17 09:19 PM
11/15/17 09:19 PM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
Hey guys,I recently picked up a pair of W2 heads P5249769 65cc closed chamber. Flat pedestals. I know they oil through the push rods.
What rockers do you guys recommend?
I have a 340 out of my 70 Dart. Would you guys use a LA block or would a Mangum block be a better starting piont?
I am not going crazy with the cam will be more of a street motor.
Any advice on intake?
Any advice would be welcome.
Brad
Re: W2 Head questions. [Re: relax383] #2404235
11/15/17 10:21 PM
11/15/17 10:21 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've never heard of any of the stock W2 race heads(with pedestals) using push rod oiling confused
As far as rocker arms, buy the best you can afford up
Don't go cheap tsk twocents
On the block as long as your not shooting for over 700 HP either block should work fine twocents That being said I know nothing about the magnum blocks, 318 or 360 shruggy
Re: W2 Head questions. [Re: relax383] #2404246
11/15/17 10:34 PM
11/15/17 10:34 PM
Washington
madscientist Offline
Washington
If you can find some of the MP rockers, or Crane or the ductile iron MP rockers are just fine.
95% of rocker failures is geometry related. The other 5% is junk lifters and flexible pushrods.
Re: W2 Head questions. [Re: relax383] #2404304
11/16/17 12:12 AM
11/16/17 12:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I just swapped from Erson to Harland Sharp rockers on race W2s. They oil through the head just like a standard LA head. The harland sharp stuff is very nice although not cheap. I had to re-shim the side clearance on one head several times to get the side clearance right and the other side bolted right up. When I asked them about extra shims etc they gladly sent shim kits to me. Good product, good service.
68 Barracuda Formula S 340
Re: W2 Head questions. [Re: relax383] #2404330
11/16/17 01:17 AM
11/16/17 01:17 AM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
I am not sure I can use HS rockers. According to what I think I know the P5249769 heads don't oil through the head.
Re: W2 Head questions. [Re: relax383] #2404357
11/16/17 02:16 AM
11/16/17 02:16 AM
Washington
Washington
I just looked up the part number and it doesn't say pushrod oiling.
Re: W2 Head questions. [Re: relax383] #2404362
11/16/17 02:29 AM
11/16/17 02:29 AM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
I am happy to be wrong on this one actually I prefer HS shaFt system
Re: W2 Head questions. [Re: relax383] #2404377
11/16/17 03:42 AM
11/16/17 03:42 AM
Washington
Washington
I'm making the ASSumption that the book would say it's pushrod oiling if it was.
Off the top of my head I don't think they made a 59* head without oiling provision for shafts.
It's easy to tell. The first and fourth rocker stands should have holes in them from the stand to the deck. Then you'll know for sure.
Re: W2 Head questions. [Re: relax383] #2404449
11/16/17 12:40 PM
11/16/17 12:40 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Much to my surprise these heads came with instructions. What a concept.
Also to my surprise they do appear to be push rod oiled and T&D rockers required.
"Instruction Sheet DCF-288a
For MP W2 “Pro Race” Cylinder Head P5007355 and P5249769
Revised 6/03/03
This package consists of one “Pro Race” cast iron W2 cylinder head and this instruction sheet. This W2 head is fully machined and is designed to fit all production “A” engine blocks, the 340 Replacement Block
P5007552, and “R3” blocks w/ the 59-degree tappet bore (P4876791AB, P4876792AB, P4876793AB, P4876794AB, P4876795AB, P4876796AB, and P4876797AB). Most of the “R3” blocks will have two extra head bolts per cylinder that will not be used with the W2 cylinder heads.
This cylinder head is not recommended for use on 48-degree tappet bore “R” blocks. If you want to use a 48-degree tappet bore block you should use W2 cylinder head P5007445AB or P5007708AB instead of this
head.
Part number P5007355 includes a 68cc closed chamber. Part number P5007769 includes a slightly smaller 65cc closed chamber. Obviously, these chamber sizes will change the compression ratio of the engine, if no other changes are made. All 59-degree wedge small block cylinder heads have an 18-degree valve angle (including these W2’s and production small block cylinder heads).
Special Notice: The rocker stands on this head are machined to work with T&D rocker arms only (for heads machined after 1/10/02). Other rocker arms will not fit and cannot be used with this cylinder head.
The T&D rocker arms are oiled through the pushrods only (not through passages in the head). This change was made to update the W2 for racing, and allow the use of modern “Pro Race” rocker arms without extensive modifications to the heads. If you do not want to use the T&D “Pro Race” rocker arms, you should use another version of the “W2 Classic” cylinder head (i.e. P4529994, P4529995, P5007089, P5007445, P5249770).
Standard “A” engine intake manifolds will not fit the W2 cylinder heads (the W2 has a different bolt pattern and port shape). See below for the suggested W2 intake manifolds. Standard “A” engine valve covers and valve cover gaskets can be used on W2 cylinder heads.
Suggested Component Parts and Accessories:
Rocker Arms: Contact T&D Machine Products at telephone (775) 884-2292
Tappets: Aftermarket w/ oil passages for rocker arm oiling
Pushrods: Aftermarket w/ oil passages for rocker arm oiling
Head Bolt Kit: ARP part number 144-3601
Head Stud / Nut Kit: ARP part number 144-4202
(Note: 12 point reduced size ARP nuts / bolts must be used to match the smaller counter bore that has been machined in this cylinder head)
Wide Valve Covers: P4876124 – for increased valve spring / rocker arm clearance
Intake Valves: P5249195 (2.020” w/ 3/8” valve stem – long valve “A” engine)
Exhaust Valves: P5249197 (1.600” w/ 3/8” valve stem – long valve “A” engine)
Valve Springs: Use Long “A” engine valve springs 1.83” to 2.0” long (see MPP Catalog)
Suggested Intake Manifolds:
Mopar Part Number: Material: Deck Height: Description:
P5249572 Aluminum 9.560-9.600” 4 bbl Dual Plane Intake
P5249572AB Aluminum 9.200” 4 bbl Dual Plane Intake
P4529408 Aluminum 9.560-9.600” 4 bbl Single Plane Intake
P4876829 Aluminum 9.000-9.200” 4 bbl Single Plane Intake (small port)
P4876829AB Aluminum 9.000-9.200” 4 bbl Single Plane Intake (standard port)
Suggested Gaskets Sets:
Mopar Part Number: Description:
P4529454 Cylinder Head Gasket Set – up to 4.100” bore
P4349557 Cylinder Head Gasket Set – up to 4.060” bore
P4120094 Cylinder Head Gasket Set – up to 4.060” bore (thin .026” design)
P4876103 Exhaust Header Gasket Set – dual bolt pattern
P4120210 Intake Manifold Gasket Set - .030” thick
P4120211 Intake Manifold Gasket Set - .045” thick
P4007571 Intake Manifold Gasket Set - .060” thick (recommended for best port alignment)
P4876446 Intake Manifold Gasket Set - .090” thick
P4007570 Intake Manifold Gasket Set - .120” thick
Special Cometic racing head gaskets are also available from Evernham Performance Parts at phone (704)
786-1909.
Most racing T&D rocker arms are oiled through the pushrods. The oil passages in the cylinder block MUST be plugged when the rocker arms are oiled through the tappets / pushrods. The oil passages through
the heads are not drilled in these two versions of the W2 heads, and the rocker arms must be oiled through the tappets and pushrods. These special T&D rocker arms MUST be used w/ tappets and pushrods that
have the oil passages to supply the oil to the rocker arms. You may want to consider using tappets for the AMC 360 V-8 engine since they have the same diameter as the small block Mopar engine and have the
passages for oiling the rocker arms / valve gear. Hollow tube pushrods must also be used when the rocker arms are oiled through the tappet / pushrods. Hollow pushrods can be special ordered from several suppliers (i.e. Crane Cams, Competition Cams, etc). Be sure to measure the length of the pushrods prior to ordering since these can change due to different deck height, and different tappet height.
This head is recommend for use with long “A” engine valves P5249195 – 2.02” intake and P5249197 –
1.600” exhaust. These heads should also be used with “A” engine long valves (see the current Mopar
Performance catalog for specific part numbers).
For additional information on W2 cylinder heads please see the Small Block “A” Engine Book from Mopar
P4876826, and the Mopar Late Model Engine book P5007450.
(DCF-288a) "
Re: W2 Head questions. [Re: relax383] #2404470
11/16/17 01:32 PM
11/16/17 01:32 PM
Washington
Washington
I wonder why the book doesn't have that info?
Now we know they are PR oiling.
This is why getting old sucks. I bought my W-5 heads in 1999 and I didn't think they made any 59* heads that were PR oiling only.
Re: W2 Head questions. [Re: relax383] #2404538
11/16/17 04:38 PM
11/16/17 04:38 PM
Oceanside CA
relax383 Offline OP
relax383  Offline OP
Oceanside CA
340 Cuda thank you for posting the instructions. I did not have them. I guess I will be calling T&D. I b appreciate everyone's help
Brad
