What battery and why, new build clean sheet of paper #2403500
11/14/17 02:05 PM
11/14/17 02:05 PM
Indianapolis In. usa
Quickrunner Offline OP
New build, clean sheet of paper. What battery (leaning towards Optima) group size? post configuration? And why
Will be trunk mounted and have master disconnect bracket already welded to cage. build is drag week type car and will have electric water pump, fuel pump, Dominator EFI, fans, AC, etc etc...and will run a 1 wire type alternator.
Looking for a clean, trouble free install and NHRA legal hold down system. Some of these aluminum hold downs I see for sale on line don't look sturdy enough to pass tech.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403513
11/14/17 02:38 PM
11/14/17 02:38 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would look at the 16v systems. Chris Alston Chassis Works has a nice battery box/hold down.
Rock Racing Batteries
http://rockracingbattery.com/home.php?cat=3
XS Power
http://4xspower.com/shop/product-category/14v16v-agm/
Chis Alston
https://www.cachassisworks.com/c-206-battery-boxes.aspx
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403520
11/14/17 02:51 PM
11/14/17 02:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
The answer depends on what you are going to do with the car. Street or bracket vs. heads up. If weight matters, lithium is the way to go.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403523
11/14/17 02:53 PM
11/14/17 02:53 PM
Renton Washington
Triple Threat Offline
Renton Washington
https://indurapower.com/product/series-220/
I am getting one of these for my new project. Not cheap but I have to keep the battery up front per class rules, so it makes sense for me.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403794
11/15/17 12:40 AM
11/15/17 12:40 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Optima is easy, replacements are available on the road, there is many different hold down options available, and they work well. I run EFI, Two Electric fans, Electric water pump, two fuel pumps, and all the other street car crap. My Yellow top is 7 years old and has 5 drag weeks and lots of passes on it, it is doing great. I work for a battery company and I put a load test on it every year before I go on drag week and so far so good. I do load up a spare for drag week but have yet to need it.
If you go optima you will want a yellow or blue top. They are the same battery but different layouts and warranty. The yellow has top and side posts and the blue has an automotive post and a 5/16th stud because it is designed for marine use. While the batteries are the same under the cover they carry different warranties, the yellow has a 36 month free and the blue a 24 month.
The downside is of course the weight.
68 Barracuda Formula S 340
Re: What battery and why, new build clean sheet of paper [Re: Bad340fish] #2403800
11/15/17 12:47 AM
11/15/17 12:47 AM
IN
ahy Offline
ahy  Offline
IN
For battery in trunk I like AGM. Red top, blue top or other. Conventional batteries seem to eventually spill acid. Not good and expensive in the trunk. AGM seems trouble free in this respect (at least has been for me).
Re: What battery and why, new build clean sheet of paper [Re: ahy] #2403834
11/15/17 02:32 AM
11/15/17 02:32 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Carrying around a bunch of unnecessary weight is hard on parts.. I recently switched out my red tops.. to a pair of Antigravity 720's we took the car out for a weekend of racing.. and ended up running just a single battery. That only weighed 3 lb.. these batteries are amazing.. today I picked up a 780 to do some more testing. It weighs approximately 4 lb.. they get a little nervous because I don't have an alternator.. but so far so good
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: What battery and why, new build clean sheet of paper [Re: WHITEDART] #2403835
11/15/17 02:34 AM
11/15/17 02:34 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
this is the temporary home.. it is sitting in the old red top footprint..
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403846
11/15/17 03:38 AM
11/15/17 03:38 AM
For your deal I would buy and use a group 27 RV/Marine battery,(conventional lead acid or AGM up) they can sit for long periods of time unused and still stay charged up up
Re: What battery and why, new build clean sheet of paper [Re: Triple Threat] #2403927
11/15/17 12:40 PM
11/15/17 12:40 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Nice find!
I was looking at this:
https://earthxbatteries.com/shop/etx1200
but the low reserve capacity had me concerned for something that will see street use. the Indura unit is almost 2x the capacity for the same price. LiFePO4 is definitely the way to go IMO
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403935
11/15/17 01:01 PM
11/15/17 01:01 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Tons of lithium batteries out there. HOWEVER the big issue with them is charging rate and maximum voltage. When they get over charged they tend to combust. The problem with your set up is the alternator. You will note they all have a maximum rate and voltage for charging. If you go this way make sure you alternator does not exceed these numbers. The fires that involve lithium batteries are usually caused by over charging them, either rate or voltage. Having said that just follow manufactures direction and they work very very well. Will crank the engine over effortlessly as well. But don't follow their instructions make sure you have good insurance. I run a single Lithium ion battery in my TS car. Cranks the thing over way better than the two 16V AGM's it reaplced. And weighs 8lbs as it is in a conventional group 24 sized case.
Re: What battery and why, new build clean sheet of paper [Re: Al_Alguire] #2403963
11/15/17 02:14 PM
11/15/17 02:14 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
What brand/model do you use?
Is it 16V or no need for 16V with this setup?
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2403969
11/15/17 02:23 PM
11/15/17 02:23 PM
Las Vegas
Las Vegas
Mine are 16v by preference. Since I switched to 16V years ago I would never go back. Car cools down so much faster this way. Mine is a Lithium Pro and a Go Lithium
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2404027
11/15/17 04:41 PM
11/15/17 04:41 PM
Weight is not an issue for me, car will be heavy anyway since its not a gutted bracket car. Not really interested in the Lithium deal. I have had good luck in the past with Optima red tops so may just stick with what I know works. I am intrigued with the yellow top and its better warrantee and the dual top & side post. Holley insists on direct connection to the battery for the EFI main power harness and this way I can dedicate the side terminals for that and run the top posts to standard ground and main push/off disconnect to power rest of the car.
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2404031
11/15/17 04:58 PM
11/15/17 04:58 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Had a bunch of different batteries over the years. Finally sticking with interstates. They have yet to let ne down
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2404037
11/15/17 05:10 PM
11/15/17 05:10 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Optima. Because I was at the track one day and watched a guy crank a SBC that wouldn't start for 30 minutes. Plus, I hear they last forever.
2011 Drag Pak Challenger
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2404048
11/15/17 05:24 PM
11/15/17 05:24 PM
Renton Washington
Renton Washington
Since weight isn't an issue, I'd say just go with the Yellow Top Optima. That is what I have in my Dart.
-Dustin
Re: What battery and why, new build clean sheet of paper [Re: Triple Threat] #2404057
11/15/17 05:34 PM
11/15/17 05:34 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I sure miss the old Sears Platinum batteries. 200.00 on sale with a 5 year free replacement. Matt and I still have one in our race cars
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2404083
11/15/17 06:10 PM
11/15/17 06:10 PM
Las Vegas
Las Vegas
Guess I should have added for what you are doing I to would steer clear of lithium stuff..IMO I see no issue with an Optima. I personally have a Napa battery in our Camaro. Been there for years and rarely does the car move but it always starts for its three drives a year smile
Re: What battery and why, new build clean sheet of paper [Re: Quickrunner] #2404109
11/15/17 06:44 PM
11/15/17 06:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Go with the yellow over the red, the reds are designed for cranking only. The yellow is better suited for something that does some cycling like running fans and pumps with the engine not running.
