Re: por-15 [Re: racerx] #2403991
11/15/17 03:06 PM
11/15/17 03:06 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I've had great luck with it patching rusty floors. POR-15 combined with fiberglass has made some very strong and very long-lasting patches for me since the '80s. I have had it peel off when I tried it over clean metal and had it fail on a master cylinder.
Plaza front passenger floor pan.jpgPlaza front passenger floor pan (2).jpgPlaza front passenger floor pan (3).jpg
Re: por-15 [Re: 71charger] #2404116
11/15/17 06:54 PM
11/15/17 06:54 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
No such thing as a chemical cure for a mechanical problem.
If you have rust, cut it out and replace the metal.
I have mechanical Aptitude.
I can screw up anything.
Re: por-15 [Re: bboogieart] #2404158
11/15/17 08:01 PM
11/15/17 08:01 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Trash!
This opinion is after brushing it on, spraying it on and following their instructions.
Snake oil!
Use a good epoxy primer like PPG DP90LF.
Honestly, Rustolem out of a rattlecan holds up 10x better than POR-15!
I want my $@#! money back!
'63 Dodge 330
11.19 @ 121 mph
Re: por-15 [Re: bboogieart] #2404198
11/15/17 09:10 PM
11/15/17 09:10 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
????????? hop
Yes the best solution is the elimination of any cancer.
However the problem is chemical. Rust is a chemical reaction. In particular its the formation of certain iron oxides and iron hydroxides. Chemically or electrochemically, they are reversible. However the steel will never be the same again. The hydroxides are a major problem - the flakey rusts that form tiny pockets where moisture is retained. These are a key part of the rusts that grow and grow.
Its the tiny pockets and the dust that will cause a film forming polymer to fail even if it seals out new moisture. However, if there is a good surface to adhere to, a rust converter or rusty metal primer has a good chance of working when topped with a non-permeable coating.
Re: por-15 [Re: racerx] #2404203
11/15/17 09:23 PM
11/15/17 09:23 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This stuff is evil.
I have worked on cars with this crap slathered on and it sucks. Try to sand or feather edge this crap....Not good.
Re: por-15 [Re: Mattax] #2404401
11/16/17 07:40 AM
11/16/17 07:40 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Agreed, I over simplified the response.
I get Oxidization is a chemical process.
My meaning was the only proper cure is the physical act of replacing the damaged metal.
Re: por-15 [Re: racerx] #2404444
11/16/17 12:28 PM
11/16/17 12:28 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
I've used POR-15 for years and never had a failure. Including an entire 1953 Chevy pickup frame which has been on the road for 15 years now and the frame still looks perfect. The trick is to follow their directions and use their cleaners and prep spray. If you do that it will work....at least it does for me.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: por-15 [Re: Centerline] #2404700
11/16/17 11:44 PM
11/16/17 11:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You have been very fortunate!
Following their directions and using the entire "treatment process" to the "T" still resulted in many failures, on several different levels. When it works, it was great, but when it failed, it failed miserably. The problem was you never could be sure which outcome you were going to get until the party was over. For what the stuff costs, it should work the perfectly every time, and that wasn't the results me and many others have gotten. Gene
Re: por-15 [Re: poorboy] #2404716
11/16/17 11:57 PM
11/16/17 11:57 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
I'm one that had bad results. Followed the directs to a 'T' since it was so dang expensive and, if anything, the rusting process seemed to speed up under the treated area. Where I had pitted metal when I applied it, a few years later, there was a gaping hole.
This was on a trunk pan, out of the weather, and not even getting wet from the underside as it was above the gas tank.
I have a pair of fenders in storage I need to pull out and take pics of. One fender I painted with just plain ol' Rustoleum the other POR15........20 yrs later, guess which one shows rust. Neither fender has been on a car since painting, always stored inside out of the weather.
Straight up crap.
I'd like to believe the formulation has improved in the 20 yrs since I last used it, but, I know it hasn't.
John
Re: por-15 [Re: racerx] #2404724
11/17/17 12:08 AM
11/17/17 12:08 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
It's very sensitive to humidity too... I use similar products, but never por-15 anymore. Only por-15 ever peeled off for me.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: por-15 [Re: racerx] #2404734
11/17/17 12:22 AM
11/17/17 12:22 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
another band aid that might stick for a while
but it does nothing to heal the wound...
Re: por-15 [Re: poorboy] #2404924
11/17/17 12:56 PM
11/17/17 12:56 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Same here. I dumped a bunch of money into it including all their prep products and followed all their instructions. I still have a gallon of their metal prep product in my garage.
Re: por-15 [Re: racerx] #2406248
11/20/17 08:44 AM
11/20/17 08:44 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Seems like a lot of people have not had luck with this stuff frown glad I ask before purchasing it. Rattle rust oleum seems to just as Good shruggy,lots of good response here .....Thaxs fellas wave
Re: por-15 [Re: racerx] #2410556
11/29/17 05:59 AM
11/29/17 05:59 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I went with Chassis Saver. It's tough as nails.
I’m listening.
