Page 2 of 4 1 2 3 4
Re: Flat cam [Re: CSK] #2402164
11/11/17 09:52 PM
11/11/17 09:52 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Love the Lucas hot rod oil. High in Zinc, and designed to cling for cars that dont get driven all the time
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Flat cam [Re: CSK] #2402165
11/11/17 09:53 PM
11/11/17 09:53 PM
P
Porter67 Offline
Porter67  Offline
P
Mis matched parts?
With the beck lifters I use billet cores as ive been down the cast core "short life" road.
Re: Flat cam [Re: BradH] #2402166
11/11/17 09:53 PM
11/11/17 09:53 PM
Pattison Texas
CSK Online shake_head OP
CSK  Online Shake_Head OP
Pattison Texas
Originally Posted By BradH
Originally Posted By csk
Well I started getting some oil pressure fluctuations & so I dropped the oil pan, looking up I could see my cam was going flat,so much for my EDM tool steel lifters, all 16 lobes are going away, 4300 miles, main bearings dont look to good, REBUILD time, GRRRRRRRRRR never again will I use a FT cam, time for roller.
Sorry to see this and why I went roller and never looked back.......the guys that tell ya it's a hassle to keep em lashed or whatever are probably the same ones who say EFI is easier and less work than a carb........DO IT and you will love it but I'd go solid.......... beer
it was a solid, going back solid roller
What brand cam? How aggressive are the lobes? Was the cam nitrided, as well as used with tool steel EDM lifters?
Howards cam .875 lobe,very mild.
no nitride.
Re: Flat cam [Re: CSK] #2402176
11/11/17 10:01 PM
11/11/17 10:01 PM
Pattison Texas
Pattison Texas
Thanks Guys for the input, solid roller is next & freshen up the short block, no more flat tappet cams for me ever again. Howards is going to call me ,they want to talk to me about this problem.
Thanks again everyone !! smile
Re: Flat cam [Re: CSK] #2402182
11/11/17 10:05 PM
11/11/17 10:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'll be interested to hear their take on what's happening there.
Re: Flat cam [Re: fast68plymouth] #2402186
11/11/17 10:09 PM
11/11/17 10:09 PM
Pattison Texas
Pattison Texas
I will post the info, they contacted me on my Facebook page.
Re: Flat cam [Re: sgcuda] #2402188
11/11/17 10:10 PM
11/11/17 10:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By sgcuda
You might still have another issue. Worn cam lobes won't cause oil pressure issues.
iagree Maybe I'm not seeing it, but I don't really see a flat cam. Seeing metal fines anywhere? Bearings and skirts - how do they look. The wear might not be right on the cam, but I would put it back in and measure it to see what you really have and make sure you identified the problem.
Re: Flat cam [Re: CSK] #2402199
11/11/17 10:22 PM
11/11/17 10:22 PM
Pattison Texas
Pattison Texas
more cam pictures
Re: Flat cam [Re: CSK] #2402208
11/11/17 10:33 PM
11/11/17 10:33 PM
That cam is definitely dead down
Re: Flat cam [Re: CSK] #2402215
11/11/17 10:40 PM
11/11/17 10:40 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Lost 1/2 a racing season after wiping out a new MP cam, broke in as usual with Comp additive. Put in an off-the-shelf Comp cam and good to go. Never waste my money again on defective MP cam.
Re: Flat cam [Re: CSK] #2402227
11/11/17 10:55 PM
11/11/17 10:55 PM
So. Burlington, Vt.
So. Burlington, Vt.
Here's my theory.......
With an iron cam and lifters, at the microscopic level, the cam and lifter material "flow", or "give", with each other during contact.
The Schubek/tool steel style lifters are so much harder than the cam core, that only the cam is flowing during contact.
"X" amount of material flow is going to happen with a given area of contact and load. If one of the pieces is so hard that it no longer flows, then all of the displacement/flow is taken up by the remaining piece. In this case, the cam.
This additional "flexing" of the surface layer of the cam under the high loads at play work harden the cam surface, and as a result it loses it's ability to "flow"....... The surface becomes brittle........ which causes fracturing, and tiny pieces of cam break away.
This goes on continually, so it looks like it's "wearing", when in reality it's more like tiny pieces are just flaking off/breaking away.
That's my theory anyway.
I may not have it 100% correct, but I'm pretty sure that's the gist of what's going on.
If the OP had used regular edm lifters, I doubt there would have been any issue.......provided he got the cam broken in properly at the start.
I feel this is one of those situations where there was a part developed to eliminate a very specific problem in certain classes of racing engines, and it seemed like a good solution to help with a similar problem with some street applications....... And in reality...... The race car parts proved to not really be suitable for street/long term use.
Re: Flat cam [Re: CSK] #2402293
11/12/17 12:52 AM
11/12/17 12:52 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That's what I meant, Solid roller............wasn't clear I guess....... thumbs
Re: Flat cam [Re: fast68plymouth] #2402296
11/12/17 12:55 AM
11/12/17 12:55 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Have a cam that looks almost identical.... Schubeck lifters... There was no indication of a problem until disassembly. Had many miles, and many passes
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Flat cam [Re: CSK] #2402346
11/12/17 02:37 AM
11/12/17 02:37 AM
Az
Crizila Offline
Crizila  Offline
Az
The only lifters I will ever run are those suggested by the cam manufacturer. I am not a metallurgist. I run almost all flat tappet cams ( soild and hyd). I run a quality synthetic oil with zinc. I make sure the lifter bores and lifters are perfectly clean ( lifter bore drop test). I rotate the engine by hand with the intake off to make sure all lifters are rotating. I don't have compatibility problems and I don't have flat tappet cam failures.
Fastest 300
Re: Flat cam [Re: CSK] #2402463
11/12/17 01:30 PM
11/12/17 01:30 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
work Interesting thread.
When I built this current engine (540 Hemi), I was conflicted as to whether I should go with a solid flat or roller cam. It is primarily a street combo, so durability was a prime concern. I asked on here and I asked quite a few experienced Mopar engine guys about which to go with.
And just like this thread, the experiences were fairly well split between the 2. No clear cut winner.
Since I got the reciprocating assembly from Ray Barton and he has a little bit of experience in this area, I went with his recommendation which was his tool steel flat lifters.
2,000 miles with VR-1 oil and no problems.......so far. But I will keep an eye on the lobes and if I see any problems developing, I will let everybody know.
Master, again and still
Re: Flat cam [Re: fast68plymouth] #2402473
11/12/17 01:47 PM
11/12/17 01:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
From what I have seen over the years....... The Schubeck/tool steel type lifters are not the hot ticket for "street" cars.
I know of numerous people who have been through this.
After you get the cam out, if you can, get some close up pics of the nose of the lobes, so I can see if they look like others I've had in the shop.
When it's a real street car(more driving, less racing), and won't be running a roller cam...... My preference is not to use real aggressive lobes, get the cam nitrided, and use normal edm lifters.
And of course high zinc oil....... And I'm not in the "light oil" camp.
I prefer the Driven or Brad Penn myself.
Edit: I didn't see the cam pic in the first post initially.
The wear and pitting on the nose like you have is what I usually see when using this style of lifter on iron cam cores when "normal" cam profiles are used.
"Cheater", or dwell at full lift type lobes seem to hold up much better when this style of lifter is used, even with much higher spring loads.
Nitriding doesn't help at all.
I've never gotten a good answer on what's happening, but I have a theory.
It's not "defective" parts, and I don't think different oil would solve it.
Thats just what was done to mine as Dwayne speced and had my custom grind solid flat tappet cam made and nitrided it. He also sent me the EDM lifters. I use the Valvoline 20W-50 VR1 racing oil and add a small bottle of the zinc additive at each oil change. I fired my eng in June 2011 and drive it on the street all the time and its still going strong. I had the inner springs out also when I broke the cam in. I have been very happy with my solid flat tappet but I hear your pain as I hate to see anyone wipe a cam. I can honestly say I have never run a roller cam and I have never wiped a cam lobe on any of my flat tappet cams. I hope my good luck holds out the rest of my life. Good luck with yours and sorry to see that happen to your eng. Ron
Re: Flat cam [Re: Crizila] #2402584
11/12/17 04:00 PM
11/12/17 04:00 PM
Pattison Texas
Pattison Texas
When I ordered my Howards cam They knew I was going to run tool steel lifters on the street & strip ,they said that was ok.
Re: Flat cam [Re: CSK] #2402592
11/12/17 04:24 PM
11/12/17 04:24 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Your cam and lifters might not have been the issue, just a result. If you are losing oil pressure, you need to find and correct that problem first.
[image][/image]
Re: Flat cam [Re: sgcuda] #2402598
11/12/17 04:34 PM
11/12/17 04:34 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Yup, further investigation into low oil pressure is needed...cam/lifters may be victims.
Re: Flat cam [Re: CSK] #2402603
11/12/17 04:47 PM
11/12/17 04:47 PM
Pattison Texas
Pattison Texas
thats why I am going back through it, the oil pump drive bushing was worn real bad also.
Page 2 of 4 1 2 3 4
