Re: 440 Daily Driver
[Re: 74RALLYE]
#2402088
11/11/17 07:59 PM
11/11/17 07:59 PM
RapidRobert
stroke it (& get quench & the SCR & the cam exactly what you want/need). I would get one of those carbs that have all of its' systems adjustable
[Re: BSB67]
#2402117
11/11/17 08:31 PM
11/11/17 08:31 PM
Posts: 5 NC
Nick Stev
NC
Why the -6 pistons & 84cc heads? Why not flat tops & 74cc heads? If it is a 2.06" CD piston, zero decked, it would probably be about perfect with a 84 cc head, going from memory. According to the website its 2.062”.
[Re: Nick Stev]
#2403456
11/14/17 12:32 PM
11/14/17 12:32 PM
Posts: 4,405 Michigan
MarkZ
Worthy
Worthy
Might want to consider something with a steeper overdrive. 0.82 and 3.55 gear will give a final ratio of 2.911; which is even numerically higher than what I'm running with a 4.10 and 0.69 OD. RPM is a bit high for a daily driver for me on the freeway, especially if you treat speed limits like guidelines.
[Re: Nick Stev]
#2403504
11/14/17 02:13 PM
11/14/17 02:13 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
EFI will make it nicer for daily use for sure, but I would not expect better mileage necessarily...
On my 493" I would get 14mpg with a 750 vac sec holley, and 10-11mpg with a 950 HP. Both with a little attention to IFR and PVR tuning. The best I got with the FITech has been 14mpg so far, and it took quite a bit of tuning to get there. This is with 3.55's and a 28" tire, no OD, non-lockup 9.5" converter. I cruise at ~3000-3200 rpm on the freeway, ~70-75 mph. I can fit a 30" tire, but got tired of swapping tires.
I'd put a long arm and a light rotating assembly in it. Otherwise, I am jealous that you live somewhere that you can daily drive something cool...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: minivan]
#2404000
11/15/17 03:33 PM
11/15/17 03:33 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Never had a 440 that averaged much better than 6 mpg.. I know, I know, someone on here gets 22 mpg with there 440.. Yeah right...
If you haven't driven a car that gets 6 mpg recently, the fuel gauge moves about like a tach needle does... Really quickly.... 6 mpg??? That's what a 10,000 pound 440-powered RV would average. I think some can even get closer to 8 mpg. Even my Satellite with a 440/727/3.91 gears with an 850 Holley double pumper averages 8 mpg.
[Re: 74RALLYE]
#2404009
11/15/17 03:53 PM
11/15/17 03:53 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
For every person that says they had good results with the Edelbrock 750 or 800 on a normally aspirated 440,there's 10 that didn't. I've used the 750 and 800 on warmed over 440s and found that unless the timing is dialed way back, the only fix is a different brand carb. Try doing a search for "Edelbrock off idle stumble/dead spot", It's a common problem. I experienced the same results on multiple cars. My 440, a 360, a warmed over 351 Cleveland, 302 with cam and heads, and the list goes on. I could get a bit better power out of the Holley (VS and DP) but the street manners and mpg was always better with the AFB. For a while I had a Holley DP that I would drop under the turbos to get better power but it always got swapped for an AFB on the street. I ended up ditching the Holley and putting an alcohol injector above the AFB for big power under boost.
[Re: 67Satty]
#2404110
11/15/17 06:45 PM
11/15/17 06:45 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
If you haven't driven a car that gets 6 mpg recently, the fuel gauge moves about like a tach needle does... Really quickly.... 6 mpg??? That's what a 10,000 pound 440-powered RV would average. I think some can even get closer to 8 mpg. Even my Satellite with a 440/727/3.91 gears with an 850 Holley double pumper averages 8 mpg. 6 or 8 mpg, they both suck..... When I was in High School (circa 73) my GF lived across town.. I would take my fathers car to pick her up in and then transition to my car (in my pic) to be able to afford to even go out that night... All I ever remember is being low on gas in that pig..... and it was 36 cents a gallon... I now have the red 67 ( less two carbs than the A12 car) and I am looking for gas at 100 miles on a tank... Red car has original block 040 over, original 915 heads, original HP exhausts, original carb and manifold, and a stock 375 HP cam.. Compression was lowered ( using forged pistons) to appx 9.2-1
[Re: DaytonaTurbo]
#2405537
11/18/17 05:39 PM
11/18/17 05:39 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I'm getting 14mpg driving my Diplomat every day.
I'm running two 500 edelbrocks on a .528 cammed, edelbrock headed 440 with 3.31 gears, running 3-3400 rpm on the highway.
The 528 cam with the 3.31's in a diplomat must make for a fun driver! The A833 between em makes it a blast to drive. I love it.
