Page 4 of 4 1 2 3 4
Re: A-727 help [Re: geo.] #2398996
11/05/17 06:55 PM
11/05/17 06:55 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
no, just a basic build. The engine really didn't need much as the crank just needed polished and heck, the bores were only .003 out. It just needed honed enough to take the glaze out. So just a hot tank, polish the crank and a quick hone.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: A-727 help [Re: geo.] #2399121
11/05/17 11:41 PM
11/05/17 11:41 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
I never got it to full. I just got it to the point where the pump picked up the fluid and started pumping it. when it did, it started to stream out when in neutral or in gear. it's pretty bad.
Re: A-727 help [Re: reno340] #2427729
01/02/18 02:24 PM
01/02/18 02:24 PM
Maryland
reno340 Offline OP
reno340  Offline OP
Maryland
UPDATE: I did finally find the culprit. My new torque converter was cracked at the base of the snout. It was so fine of a crack that I could not see it without pressure testing it. Here is a youtube video of my home made pressure tester for the torque converter.
https://www.youtube.com/watch?v=QDhz3MSemv8
Re: A-727 help [Re: reno340] #2427737
01/02/18 02:40 PM
01/02/18 02:40 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I am glad you found it. Does B&M not pressure test their converters? What a pain. I would be tempted to send it back and ask for a refund and go with another company. I've used Turbo Action and Dynamic with good results. Costs more, but I think a better quality unit.
Page 4 of 4 1 2 3 4
