Re: Another avenue..............
[Re: Thumperdart]
#2398030
11/03/17 05:10 PM
11/03/17 05:10 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I think mine is just a moog product, it has been on the car several years with no issues. The best thing I ever did for my steering was buy a steering box from a friend that only had 30,000 miles on it. It was like I got a new car.
68 Barracuda Formula S 340
[Re: Thumperdart]
#2398076
11/03/17 06:38 PM
11/03/17 06:38 PM
Posts: 4,457 Washington
madscientist
Washington
Instead of the rack for now, who sells the best idler arm for a-bodies that will tighten up the slop I'm experiencing...........Anyone make a rollerized one............ Call Firm Feel. They have all kinds of stuff like you want.
[Re: Thumperdart]
#2398126
11/03/17 08:17 PM
11/03/17 08:17 PM
Triple Threat
Renton Washington
My Dart has the 1 year only 67 style idler arm. My dart destroys one every summer from doing wheelies and such. Hoping I can convert it to the 68+ style this winter while the engine is out.
[Re: fullmetaljacket]
#2398152
11/03/17 09:48 PM
11/03/17 09:48 PM
Thumperdart
State of confusion
Thumper. I might be able to get you an original US Chrysler made arm through my boy Special K. He either has in his stock inventory or can get it for you. I'll ask him. If that's the hot ticket cool just wish someone made a rollerized unit as that would help us all who run stock front ends...........
[Re: Thumperdart]
#2398195
11/03/17 11:54 PM
11/03/17 11:54 PM
Posts: 7,506 Az
Crizila
Az
Which ever idler arm you decide to go with, after you install it, make sure the center link ( between the steering arm and idler arm )is parallel to the ground with the front of the car sitting level side to side. Just from this thread you can see how much stuff is out there and I can guarantee from past experience they aint all the same. I have found that Moog stuff is the most reliable as far as the parallel thing is concerned. After market K frames, gear boxes, and steering arms can also play havoc in this area. If you are knocking idler arms out due to wheelies you got a suspension travel problem. A hint would be cracked / busted dust boots.
Fastest 300
#2398418
11/04/17 03:47 PM
11/04/17 03:47 PM
Thumperdart
State of confusion
Moog K7042 is the arm, but one must make sure that it is a Moog and not another company with the same part number. Those are the off shore junk. Let me know via E-message if you are going with OEM stock and I'll get you in touch with Special K. Thankxxx guys I'm mounting new ft and rear Hoosiers next week then track time so can I get this stuff at Summit by chance so I can use my card......
[Re: mopar dave]
#2398429
11/04/17 04:33 PM
11/04/17 04:33 PM
Thumperdart
State of confusion
Haven't really searched that hard and would just like a stable idle arm so it stops wandering for now then maybe over the winter..........
