Another avenue.............. #2398021
11/03/17 05:04 PM
11/03/17 05:04 PM
State of confusion
Thumperdart Offline OP
State of confusion
Instead of the rack for now, who sells the best idler arm for a-bodies that will tighten up the slop I'm experiencing...........Anyone make a rollerized one............ thumbs
Re: Another avenue.............. [Re: Thumperdart] #2398030
11/03/17 05:10 PM
11/03/17 05:10 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think mine is just a moog product, it has been on the car several years with no issues. The best thing I ever did for my steering was buy a steering box from a friend that only had 30,000 miles on it. It was like I got a new car.
68 Barracuda Formula S 340
Re: Another avenue.............. [Re: Thumperdart] #2398076
11/03/17 06:38 PM
11/03/17 06:38 PM
Washington
madscientist Offline
Washington
Call Firm Feel. They have all kinds of stuff like you want.
Re: Another avenue.............. [Re: madscientist] #2398085
11/03/17 06:58 PM
11/03/17 06:58 PM
State of confusion
State of confusion
Thankxxx...........the box was rebuilt years ago but is still nice it's the idler-arm that moves around before affecting the drivers tire when I grab the passenger tire and move it back n forth so my toes outta whack because of it............. thumbs
Re: Another avenue.............. [Re: Thumperdart] #2398099
11/03/17 07:15 PM
11/03/17 07:15 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Moog or firm feel.
Re: Another avenue.............. [Re: FastmOp] #2398107
11/03/17 07:33 PM
11/03/17 07:33 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I feel like I've put 2-3 part stores idler arms on my car over the years! They cheap ones sure don't last long!
Re: Another avenue.............. [Re: Thumperdart] #2398112
11/03/17 07:41 PM
11/03/17 07:41 PM
fullmetaljacket Offline
Thumper. I might be able to get you an original US Chrysler made arm through my boy Special K. He either has in his stock inventory or can get it for you. I'll ask him.
Re: Another avenue.............. [Re: Thumperdart] #2398126
11/03/17 08:17 PM
11/03/17 08:17 PM
Renton Washington
Triple Threat Offline
Renton Washington
My Dart has the 1 year only 67 style idler arm. My dart destroys one every summer from doing wheelies and such. Hoping I can convert it to the 68+ style this winter while the engine is out.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Another avenue.............. [Re: Triple Threat] #2398141
11/03/17 09:10 PM
11/03/17 09:10 PM
I've swap to the 1968 later model b body K members out from my OEM K members 1963 Plymouth Fury and 1966 Dodge Coronet for that reason up
Re: Another avenue.............. [Re: fullmetaljacket] #2398152
11/03/17 09:48 PM
11/03/17 09:48 PM
State of confusion
State of confusion
If that's the hot ticket cool just wish someone made a rollerized unit as that would help us all who run stock front ends........... thumbs
Re: Another avenue.............. [Re: Thumperdart] #2398167
11/03/17 10:43 PM
11/03/17 10:43 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Firm Feel has a rollerized idler kit for a MOOG idler arm. Don't try to substitute any other arm they won't work. Don't ask how I know whistling
Re: Another avenue.............. [Re: Thumperdart] #2398186
11/03/17 11:34 PM
11/03/17 11:34 PM
Moog K7042 is the arm, but one must make sure that it is a Moog and not another company with the same part number. Those are the off shore junk.
Let me know via E-message if you are going with OEM stock and I'll get you in touch with Special K.
Re: Another avenue.............. [Re: Thumperdart] #2398195
11/03/17 11:54 PM
11/03/17 11:54 PM
Az
Crizila Offline
Crizila  Offline
Az
Which ever idler arm you decide to go with, after you install it, make sure the center link ( between the steering arm and idler arm )is parallel to the ground with the front of the car sitting level side to side. Just from this thread you can see how much stuff is out there and I can guarantee from past experience they aint all the same. I have found that Moog stuff is the most reliable as far as the parallel thing is concerned. After market K frames, gear boxes, and steering arms can also play havoc in this area. If you are knocking idler arms out due to wheelies you got a suspension travel problem. A hint would be cracked / busted dust boots.
Fastest 300
Re: Another avenue.............. [Re: fullmetaljacket] #2398418
11/04/17 03:47 PM
11/04/17 03:47 PM
State of confusion
State of confusion
Thankxxx guys I'm mounting new ft and rear Hoosiers next week then track time so can I get this stuff at Summit by chance so I can use my card...... beer
Re: Another avenue.............. [Re: Thumperdart] #2398427
11/04/17 04:29 PM
11/04/17 04:29 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Dom, in your searches for A body rack pinions, have you found any bolt in non power rack kits?
Re: Another avenue.............. [Re: mopar dave] #2398429
11/04/17 04:33 PM
11/04/17 04:33 PM
State of confusion
State of confusion
Haven't really searched that hard and would just like a stable idle arm so it stops wandering for now then maybe over the winter..........
