Re: BB oiling
[Re: John Brown]
#2397842
11/03/17 12:43 PM
11/03/17 12:43 PM
Posts: 19,562 north of coder
moparx
Both NPT and NPS have the same thread angle, shape, and pitch (threads per inch). However, NPT threads are tapered and NPS threads are straight.
People usually argue with me on this, but if you have a factory unit and another with NPT, you can see the difference if you compare closely, and certainly can measure the difference.
People like to argue. I bought a set of NPS taps back in the 1970's for for putting drain plugs into aluminum Muncie transmission cases. They work fine for putting a tapered pipe plug into the straight hole. You don't end up with a plug that is sunk down like you will when someone taps a hole with a tapered pipe tap. having worked with NPT and NPS threads over my 42+yr career as a machinist, almost every time an NPT male fitting is screwed into a female NPS that has a somewhat thin wall cross section, a crack WILL happen. as said, it acts just like a wedge. it may not happen upon installation, [unless tightened enough to crack, which is tough to say just how tight is tight] but if any vibration is involved, it will crack eventually.
Re: BB oiling
[Re: DusterKid]
#2397942
11/03/17 02:45 PM
11/03/17 02:45 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For the OP's proposed build plans and intended rpm range, I'd just run a 3/8" pick up.
