Re: Reverse Cowl or not
[Re: ozymaxwedge]
#2396636
11/01/17 01:28 PM
11/01/17 01:28 PM
Posts: 326 Alberta
Wookie316
Alberta
I have a cowl on my 71 only because a 6 pack scoop looks terrible on a 3rd gen Charger because it has to sit so far back on the hood. At first I hated it, but now that it has been on the car awhile it has grown on me.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: ozymaxwedge]
#2397328
11/02/17 02:48 PM
11/02/17 02:48 PM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
FWIW...when my car ran mid 10s, the cowl hood ran just as good as the 6 pack hood. What makes it better...the cowl hood wasn't sealed to the carb, but the 6 pack hood was. The seal I had on the 6 pack hood worked too...was a tenth quicker and 1 mph faster sealed up.
[Re: OUTLAWSSAA]
#2397710
11/03/17 08:26 AM
11/03/17 08:26 AM
Posts: 625 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Ideally I prefer no scoop but even with this 3.5" cowl, it was the only way to make the "hardware" fit properly. The key to a cowl hoods aesthetics I believe is to make it "flow" with the car with a tapered look, not have it come rearwards from the front with a sudden "Jimmy Durante'd" hike in its rearward height. This is especially important on a shorter wheelbase car where a taller cowl scoop take away from the lines of the car and make it look "stumpier" when viewed from the side. Mine will be sealed in due course. ![](https://s1.postimg.org/3gan2r9man/valiant-vh-charger-1-nw_2.jpg) ![](https://s1.postimg.org/3e62ppvn5b/valiant-vh-charger-side-nw_2.jpg)
[Re: LAD 524]
#2398585
11/04/17 11:02 PM
11/04/17 11:02 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Ideally I prefer no scoop but even with this 3.5" cowl, it was the only way to make the "hardware" fit properly. The key to a cowl hoods aesthetics I believe is to make it "flow" with the car with a tapered look, not have it come rearwards from the front with a sudden "Jimmy Durante'd" hike in its rearward height. This is especially important on a shorter wheelbase car where a taller cowl scoop take away from the lines of the car and make it look "stumpier" when viewed from the side. Mine will be sealed in due course. ![](https://s1.postimg.org/3gan2r9man/valiant-vh-charger-1-nw_2.jpg) Your car is stunning mate, unfortunately to achieve what I thinking I will have to go 6" cowl, the 2 carbs on top of the Indy tunnel are at about 4" out at the front. I have ordered a 6",still not sure but as it sits I have this fibre glass hood sitting here unusable so I will sit it on there and stand back for a look. Will it stand out more than with carbs and air cleaners ?? Will it be more of a cop bait ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: one bad fish]
#2399114
11/05/17 11:28 PM
11/05/17 11:28 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
I had been thinking about a cowl hood on my 1970 GTX for some time. I heard all about using a Chevy hood on my Mopar from some of my friends. I found a fiberglass hood nearby on Craigslist and bought an 8 inch tall Harwood cowl scoop. I joined the two and took it to a test and tune. That particular night we had a pretty good head wind. In my engineering mind I thought the cowl hood would help the air up and over the GTX and out toward the sides as it gets wider toward the back. I did back to back runs with my forward facing scoop hood and the cowl hood. The result was a BIG disappointment as the GTX slowed down a 10th! I would be open to ideas to make it work and if not find someone who would be interested in the cowl scoop. MJ
[Re: moparjohn]
#2399260
11/06/17 11:15 AM
11/06/17 11:15 AM
an8sec70cuda
The rear of the cowl scoop needs to be real close to the windshield for it to work and actually pull air in. I can't slide my hand b/t the scoop and windshield...palm on the glass.
