Re: 511 project hp falls short of target
[Re: Thumperdart]
#2396634
11/01/17 01:26 PM
11/01/17 01:26 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Testing for streetability, sure. Testing for max power...nope. I get BOTH but it takes time, patience and KNOWLEDGE but the end results are well worth it........I agree about hittin the track(forget the dyno)and seeing what ya got at that point then change what's necessary to meet your goal IF it doesn't already.......... Yep hit the track then you get to do the chassis tune at the same time.
[Re: mopar dave]
#2396832
11/01/17 06:50 PM
11/01/17 06:50 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
dyno is ease of repeatability and quickness of getting result . I have only used a chassis dyno but found an hour or two is a good thing . Timing loop and AF settings . Really I only depend on the AF number , if that is correct after timing loop then its time to run it down the strip . and yes the dyno can occasionally throw you a curve ball .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: mopar dave]
#2396858
11/01/17 07:22 PM
11/01/17 07:22 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
The car on a chassis dyno compared to the same car at the track has two different condition it is dealing with, just like the engine on a engine dyno compared to at the track On the chassis dyno no moving air is affecting the carb. air inlet temps and no oil is sloshing around in the crankcase, same thing on the engine dyno Hence the old adage about we don't race dyno, do we
[Re: mopar dave]
#2396918
11/01/17 08:35 PM
11/01/17 08:35 PM
Posts: 25,992 United Socialist States of Ame...
tboomer
Dave...I have been watching this. I am going to be honest and tell ya that I wouldn't spend another dime till I put it down the track a few times. Good luck!
[Re: mopar dave]
#2396981
11/01/17 09:51 PM
11/01/17 09:51 PM
Posts: 59 Florida
Sweet5ltr
Yeah, how many times have you seen engines making 550hp on the engine dyno and put 350 to the tire on the chassis dyno (in street trim). Easy to lose well over 100hp from simple accessories. Check out the recent engine masters air-cleaner shootout. Well over 100hp loss on a 650hp engine by choosing an incorrect air cleaner. Jaguar clutch fan mod is a great choice for most of us if you have clearance issues, other than running a mechanical which will cost 25-30hp alone. Good luck on your build.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
[Re: mopar dave]
#2396991
11/01/17 10:02 PM
11/01/17 10:02 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
The season is just about over for me. 40* and rains just about everyday now. Still gonna do the intake and double adj. Shocks on front. Oh, needs the 4.10 gear too. Something else i'm thinking about is the hp deficit the milodon oil pump with 20/50 oil and the mechanical water pump with flex fan is causing. May be 40-50hp right there. I dont always take the easy road. I built this combo trying to make 700+hp without all the electrical components and on pump gas. I went to Dragway42 last Friday night, got one pass in before it poured rain, hoping to go this Saturday but there's some rain in the forecast again. I agree that you just need to get it to a track, and if the season is over then maybe a chassis dyno session or wait til early spring for a track day. I've raced my whole life and I've never ever used an engine dyno or a chassis dyno. I set the timing at 34 and jet the carb with some homework. Make some passes jetting up and down, then make some passes moving the timing up and down. Then test some shift points etc. Every car I've switched over to an electric water pump has dropped 1.5 tenths in the 1/4. I'm currently running a mechanical water pump and flex fan and already have the desire to try an electric water pump, but it's a 10 second street car driven to the track so I like my mechanical setup.
[Re: ProSport]
#2397077
11/01/17 11:38 PM
11/01/17 11:38 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
The season is just about over for me. 40* and rains just about everyday now. Still gonna do the intake and double adj. Shocks on front. Oh, needs the 4.10 gear too. Something else i'm thinking about is the hp deficit the milodon oil pump with 20/50 oil and the mechanical water pump with flex fan is causing. May be 40-50hp right there. I dont always take the easy road. I built this combo trying to make 700+hp without all the electrical components and on pump gas. I went to Dragway42 last Friday night, got one pass in before it poured rain, hoping to go this Saturday but there's some rain in the forecast again. I agree that you just need to get it to a track, and if the season is over then maybe a chassis dyno session or wait til early spring for a track day. I've raced my whole life and I've never ever used an engine dyno or a chassis dyno. I set the timing at 34 and jet the carb with some homework. Make some passes jetting up and down, then make some passes moving the timing up and down. Then test some shift points etc. Every car I've switched over to an electric water pump has dropped 1.5 tenths in the 1/4. I'm currently running a mechanical water pump and flex fan and already have the desire to try an electric water pump, but it's a 10 second street car driven to the track so I like my mechanical setup. Pretty much what i have always done. I have swapped to electric fan and pump on two cars and seen right around a tenth both times. Saw a little more gain swapping out bias tires for radials, actually about .013
[Re: mopar dave]
#2397220
11/02/17 11:24 AM
11/02/17 11:24 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I like this topic, I have some experience with dyno numbers and track results. Not all dynos are created equal. When I first built my big motor I ran it on a local dyno. I got some great results, 830ish HP. I put it in my car and couldn't get it to run the number. The carb was dead lean and I ran a good 2 or 3/10's off what it should have ran. I was in the 9.20-.40 range and should have been in the 9.oh's @ 2900 lbs. I had little help with carb tuning and the dyno day was a long day to only get 4 pulls. Over the next winter I carted the motor up to Dwayne and we spent a day dialing the carb in. After his tuning, his results showed 750-775ish HP. We made a lot of pulls, I recall it was close to 20. I had added a little weight in the car by the time it got back to the track. The car ran exactly what it should have run with the power it had. It ran consistent 9.20's with a best of 9.16 with 100 lbs more in the car. I never touched a thing on the carb at the track. The next winter I ironed out a few deficiencies in my combo. We dyno'd again and picked up close to 100 HP. Now I really was in the 830-850ish HP range. Again, I put it in the car and ran exactly what it should have for the power it had. Consistent 9.oh's and a best of 8.94 @ 3000lbs Track tuning you have changing conditions. If your chassis doesn't hook every time and show a change in ET form a tuning change, the chassis may need tuning too. If you spin your MPH numbers will be higher than if you dead hook. The DA could change 400 feet in a day if it's a few hours between runs. It could change more than that on different days. There is no substitute for good engine data. The whole combo needs to work together if you are chasing ET. Butt dyno on the street does not work when you spin the tires in any gear.
[Re: B3422W5]
#2397275
11/02/17 01:04 PM
11/02/17 01:04 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
The season is just about over for me. 40* and rains just about everyday now. Still gonna do the intake and double adj. Shocks on front. Oh, needs the 4.10 gear too. Something else i'm thinking about is the hp deficit the milodon oil pump with 20/50 oil and the mechanical water pump with flex fan is causing. May be 40-50hp right there. I dont always take the easy road. I built this combo trying to make 700+hp without all the electrical components and on pump gas. I went to Dragway42 last Friday night, got one pass in before it poured rain, hoping to go this Saturday but there's some rain in the forecast again. I agree that you just need to get it to a track, and if the season is over then maybe a chassis dyno session or wait til early spring for a track day. I've raced my whole life and I've never ever used an engine dyno or a chassis dyno. I set the timing at 34 and jet the carb with some homework. Make some passes jetting up and down, then make some passes moving the timing up and down. Then test some shift points etc. Every car I've switched over to an electric water pump has dropped 1.5 tenths in the 1/4. I'm currently running a mechanical water pump and flex fan and already have the desire to try an electric water pump, but it's a 10 second street car driven to the track so I like my mechanical setup. Pretty much what i have always done. I have swapped to electric fan and pump on two cars and seen right around a tenth both times. Saw a little more gain swapping out bias tires for radials, actually about .013 Yep, the time slip is the best dyno. No two cars of the same RWHP level will ET/MPH the same.
[Re: mopar dave]
#2397285
11/02/17 01:28 PM
11/02/17 01:28 PM
Posts: 1,030 ohio
67mprfan
ohio
Okay what would be a good type or style water pump to run and be able to keep from losing power
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2397330
11/02/17 02:48 PM
11/02/17 02:48 PM
Clanton
northern,Ohio,USA
Okay what would be a good type or style water pump to run and be able to keep from losing power My Moroso has been good to me with factory housing but they also make a remote with the same pump.
[Re: mopar dave]
#2397396
11/02/17 04:36 PM
11/02/17 04:36 PM
Thumperdart
State of confusion
The moroso is a drop in electric. It will be i get if need be to get to 9's I got the NEW Moroso drop in black pump and it rocks and is more efficent and lighter than the old blue pump I ran for years...........
