Re: Best way to counter speed wobbles/fish tailing at track?
[Re: Adam71Charger]
#2395604
10/30/17 07:56 PM
10/30/17 07:56 PM
fast68plymouth
So. Burlington, Vt.
My car has never done that in like 1500 passes.
Just make sure the tires are properly inflated.
[Re: Adam71Charger]
#2395609
10/30/17 08:00 PM
10/30/17 08:00 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I've had several ill handling cars at the track, do NOT OVER CORRECT ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) If you start to feel uncomfortable lift your right foot a little or all the way off, DO NOT jerk the steering wheel around, make all steering inputs gently, a tiny bit, not a BUNCH 4 speed cars can get your schynter(SP?) really tight in a hurry at WOT Once it starts to make you feel bad do something to correct it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Don't take time to think about what to do at WOT and then do something, don't freeze up ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Adam71Charger]
#2395625
10/30/17 08:22 PM
10/30/17 08:22 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Thanks guys. I've spent years putting this car together and don't wanna crunch it.
Fast68, I'm actually in the process of selecting my tires to. I have 15x10 wheels in the back of my mini tubbed 71 charger. It's auto, 9.5 4200 converter, Dana 60 4.10, has the multi clutch posi (forget the real name of this type of diff), 446 with the st21 cam, 950hp holley, 1 7/8 long tubes into dual 3", makes 525ish hp (little more tuning to do), about 4000lbs with me, I'm gonna use drag radials but can't decide on what size, what do you think?
Cab, so basically don't over react and don't touch the brake?
[Re: dustergirl340]
#2395686
10/30/17 09:55 PM
10/30/17 09:55 PM
Posts: 2,364 PA
70HemiGTX
PA
4 speed cars can get your schynter(SP?) really tight in a hurry at WOT Yep! Why? I have a stick car and so far it has gone nice and straight with one exception at the starting line. I was the first car to go down that lane. Starting line was not prepped correctly. Immediately turned for the tree. I got out of it real fast. But like I said I never had any issues down track.
[Re: Adam71Charger]
#2395697
10/30/17 10:04 PM
10/30/17 10:04 PM
Posts: 2,873 Pattison Texas
CSK
Pattison Texas
Cab, so basically don't over react and don't touch the brake? Do not get Nitto's, I sold mine & just got some M/T ET street R, have not made it to the track yet with M/T's but on the street they hook VERY good compared to the Nitto.
[Re: Adam71Charger]
#2395721
10/30/17 10:39 PM
10/30/17 10:39 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
If you run a M/T street drag radial and all your steering and suspension is up to snuff, heat the tires a little bit and enjoy. Make a shakedown pass your first trip to get the feel for it and have fun. Don't rush yourself.
[Re: Cab_Burge]
#2395756
10/30/17 11:31 PM
10/30/17 11:31 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I've had several ill handling cars at the track, do NOT OVER CORRECT ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) If you start to feel uncomfortable lift your right foot a little or all the way off, DO NOT jerk the steering wheel around, make all steering inputs gently, a tiny bit, not a BUNCH 4 speed cars can get your schynter(SP?) really tight in a hurry at WOT Once it starts to make you feel bad do something to correct it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Don't take time to think about what to do at WOT and then do something, don't freeze up I agree don't over react,over steer,panic brake.I had to counter steer a bit in this run. https://www.youtube.com/watch?v=Ar0u7KtWH-I run
[Re: Adam71Charger]
#2395809
10/31/17 12:53 AM
10/31/17 12:53 AM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
Maybe have somebody with experience drive your car first, make sure its sorted out
[Re: Adam71Charger]
#2395814
10/31/17 01:06 AM
10/31/17 01:06 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
2 things that cause wobbles and fish tailing at speed are front end alignment and worn out tires. Get your front end aligned , the tech will check for bad joints and bushings, or he should. If your buying new tires ,you can rule that out.
[Re: cudadoug]
#2395839
10/31/17 01:54 AM
10/31/17 01:54 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
if You use a Radial, it should track straight & true. Even on bias plus, with proper inflation it should be just like the freeway. If it’s not, figure out why not. The best advice I can give is to embrace the mindset of: “if it gets loose at all, the run is over”. Roll out of it and make adjustments for the next run.
[Re: Adam71Charger]
#2395924
10/31/17 10:22 AM
10/31/17 10:22 AM
Posts: 13,405 Marion, South Carolina [><]
an8sec70cuda
If it starts to get unstable, just let off the gas. Too many try to be a hero and stay in it.
Only time I've ever had a high speed issue was w/ bias ply tires that had too little air pressure. On radials I doubt you'll ever have an issue, but keep em at 18+ psi on a 4k lb car.
[Re: an8sec70cuda]
#2395927
10/31/17 10:31 AM
10/31/17 10:31 AM
BradH
Yep. In my case, it was too wide a tire for the wheel width and I was keeping the tire pressure lower than it should have used trying to spread out the footprint off the line. Then on the big end the back end would start to sway back & forth cuz the sidewalls were too soft.
