Re: Anyone using Rotella Diesel oil in their musclecars?
[Re: GO_Fish]
#84384
07/06/08 10:14 AM
07/06/08 10:14 AM
Posts: 1,413 northeast ohio
hulmule
northeast ohio
I know when i run rotella in my cummins it smells bad. I can smell it in my cab and in the flumes.I run Delvac in my cumins.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: 68Bullit]
#84386
07/06/08 01:25 PM
07/06/08 01:25 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
What about the Chevron Delo 400? It's the same weight, but is it the same or better than the Rotella? And as far as the weight goes, is there really a big difference in the 10W and 15W?
Chevron Delo 400 LE 15W40 actually has more zinc than Shell Rotella T 15W40. I don't remember exactly, but it's above 1300 ppm zinc. At least 1200 ppm zinc is best for a flat tappet cam. I suppose 1150 ppm zinc (approximate) is OK, such as Shell's Rotella T's, for a stock engine or a mildly built engine. That's up to the individual to decide.
Shell Rotella T 5W40 full synthetic has about 1400 ppm zinc.
[Re: 300_dup5]
#84388
03/17/15 08:27 PM
03/17/15 08:27 PM
Challenger 1
Cincinnati, Ohio
Thanks Guys, new 440 here it comes
6-7 year old thread? ![](/ubbthreads/images/graemlins/eeek.gif)
[Re: Challenger 1]
#84389
03/17/15 08:33 PM
03/17/15 08:33 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Don't worry, oil additive packages haven't changed in the last 6-7 years. ![](/ubbthreads/images/graemlins/rolleyes.gif)
[Re: Challenger 1]
#84391
03/17/15 11:06 PM
03/17/15 11:06 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
For the last 30 years all I've used in everything from a brigs and Stratton to my 605 Hemi is shell rotella 15/40 HD diesel oil. Never had an oil related engine failure with it.Dave ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: quickd100]
#84392
03/17/15 11:38 PM
03/17/15 11:38 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Same here. Muscle motors even used Rotella when they dynoed my 526 Hemi.
[Re: terzmo]
#84399
03/18/15 11:22 AM
03/18/15 11:22 AM
Posts: 670 Los Osos, Ca
CKessel
Los Osos, Ca
Don't use the CJ rated oils. They are for 07.5 and newer diesels with the particulate filters and have zippo for ZDDP. Use a CI rated if you want to use diesel oil and make sure its not combo'd as CI/CJ.
Carl Kessel
[Re: Polarapete]
#84400
03/18/15 01:30 PM
03/18/15 01:30 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Yeah, I can vouch for that smell. I used it a couple of times in my '02 CTD. And I will probably use it when I finally fire the motor in the Ramcharger (it has been dormant since 2012 and it does not look to good for 2015). That 440 has a hot Comp hydraulic and I don't need lifter problems.
I use it all the time, my truck even leaks oil and yet I never noticed any kind of smell ![](/ubbthreads/images/graemlins/shruggy.gif)
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#84401
03/18/15 03:22 PM
03/18/15 03:22 PM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
I didn't really notice it until I relocated the puke tank on my '01 Cummins, but right after an oil change it does have a weird smell. Kind of an acidic smell. It seems to go away after a while...maybe as the oil gets some miles on it.
I always run Rotella in my truck, but I use Valvoline VR1 race oil in my cars.
[Re: CKessel]
#84402
03/19/15 10:53 AM
03/19/15 10:53 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I think Rotella and Delo 400 CJ-4s have about 1200-1300 ppm of zinc. I've been running it for years as have many others.
[Re: pinkduster]
#2390920
10/21/17 06:28 PM
10/21/17 06:28 PM
Posts: 15,947 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Reviving an old post; what's the attractiveness of the 20W-50 weight of the VR-1 Valvoline. I've had it recommended to me by very experienced Mopar mechanic, and I know a lot of wise Mopar people who like it. I'm just wondering, aside from the Zinc content, what's the advantage of the weight?
Would you recommend that weight in my stroked 360, hydraulic roller cam, Florida temps, no racing, just some occasional heavy footed street driving?
Facts are stubborn things.
