Get the recommended rings that go on the reaction support for the drum you are getting. I use a high pressure valve body (Griner), so I like the teflon rings. But if you get an aluminum drum with no sleeve, teflon might wear it. The teflon rings don't always rotate with the drum, metal rings (various types) have tension to rotate with the drum, but they will wear the ring grooves in the reaction support.
And when changing any hard parts, check the end play and adjust as needed.
And if you use a transbrake, they recommend a tiny bleed hole, either in the front drum, or the piston.
