Re: 727 explosion at Milan last night....
[Re: dustergirl340]
#2390259
10/20/17 12:31 PM
10/20/17 12:31 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
It was rough. He had a blanket, but everything was mangled. Overhearing the guys talk, it broke the block, bent the framerail, bent the headers. You could see the floorpan bent well past the gas pedal mount.
Insult to injury, as was mentioned, the car was pushed back over the shrapnel which cut the slick.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: dustergirl340]
#2390274
10/20/17 01:33 PM
10/20/17 01:33 PM
Posts: 11,540 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
So what failed, the roller clutch allowing the drum to burst or the converter?
ETA...NVM, now that I see the pictures.
[Re: DoubleD]
#2390301
10/20/17 02:34 PM
10/20/17 02:34 PM
fullmetaljacket
[Re: dustergirl340]
#2390319
10/20/17 03:23 PM
10/20/17 03:23 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Stock Drum...? Sorta looks like on.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: dustergirl340]
#2390331
10/20/17 03:56 PM
10/20/17 03:56 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That's ugly!!
Pretty serious carnage to that floor pan.
[Re: J_BODY]
#2390431
10/20/17 07:21 PM
10/20/17 07:21 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
yes.... but was it because it was built like a "typical" 727. OUCH!!!!!!!!! That's gonna leave a mark
[Re: dustergirl340]
#2390458
10/20/17 07:57 PM
10/20/17 07:57 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A local racer recently lost a sprag which wiped out the case and rear support. Disassembly found other distressed parts. I gave him a list of the minimum parts I would replace but he won't spend the money.
Sometimes an incident like this is the only way to make believers out of skeptics.
