Page 9 of 13 1 2 7 8 9 10 11 12 13
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316613
06/05/17 02:45 PM
06/05/17 02:45 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By Dragula
[quote=pittsburghracer]Make a few calls to possibly Indy, Best Machine, Bob George Racing, and any other shops you can think of. Who knows what they have on stock and willing to part with
I have been in touch with AJ at BGR...He got me the one quote for a Callie's...Just didn't let me know lead time.
Originally Posted By 23T Hemmee
Just in case you might be interested.
http://bo
I will keep that one in mind.
Got a call, it was straightened again and all polished up. Not sure if the guy was happy about doing it or not....We will probably heat cycle it in the oven at the shop and make a judgement call on it.
We also have a run in stand we can fire it up on and just see what happens before it goes in the car this time.
Might be something to think about.
Lets try this again.
https://www.thebalance.com/cryogenic-hardening-2340006
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: sgcuda] #2316614
06/05/17 02:46 PM
06/05/17 02:46 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Certainly was a lot of metal in the pan. I do not know how exactly they measured it. I am assuming TIR was out near the repaired journal.
Really wasn't a lot wrong with it. Hell for all I know, I could have a stuck pressure relief spring and haven't found it yet. Bearings were showing issues.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316802
06/05/17 08:02 PM
06/05/17 08:02 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The .003 out made me think that the crank was warped. I don't know how just engine heat , even 200 degrees would warp a crank. I can see how welding could . Was the crank checked for straightness after the journal was welded up ? if not is the journal now out of whack to the rest of the crank ?
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316808
06/05/17 08:06 PM
06/05/17 08:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Winberg will make whatever you want. Toured their facility past year. Not sure on lead time.
FWIW I currently have a Crower, Moldex and Bryant in my junk.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Al_Alguire] #2330315
07/02/17 07:31 PM
07/02/17 07:31 PM
Dragula Offline OP
Dragula  Offline OP
Well, we straightened the crank again, and it now has only .0001" runout....new bearings are here, so we sent it all out for line hone, again...
Then, its ready for assembly....again.
And I see the photobucket again is doing somthing to my posted pictures..
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2330512
07/03/17 03:02 AM
07/03/17 03:02 AM
Superfreak
Superfreak
They want money from you, especially since they see you spending all that money on the hemi, LOL.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: ] #2330637
07/03/17 12:53 PM
07/03/17 12:53 PM
Dragula Offline OP
Dragula  Offline OP
Us Hemi guys have no money.....need a new photo hosting sight anyways. They sucked.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2333172
07/07/17 04:46 PM
07/07/17 04:46 PM
Dragula Offline OP
Dragula  Offline OP
So they were checking it over for line hone, and we have one cap that is a little loose, and that is a little tight...This is the first we have checked that after welding it up...So they are line boring it as we speak and then we may check the balance on all the components just to make sure.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2387753
10/15/17 03:21 PM
10/15/17 03:21 PM
Dragula Offline OP
Dragula  Offline OP
Talk about a thread ruined by photo bucket wanting a ton of money every year to host my pictures....I will never pay for someone to let me host my own pictures...Good luck.
So a little update:
We have the engine all back together. Its been back together for a while now. But on the bench, we are unable to get more than 4lbs of oil pressure.
AJ, I will bringing it to you in the next week or so. Hopefully its just a small galley plug we left out and can't find or somthing stupid.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2387871
10/15/17 09:37 PM
10/15/17 09:37 PM
Superfreak
Superfreak
keep us posted on the outcome please.
Thanks.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2388135
10/16/17 01:29 PM
10/16/17 01:29 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
You definitely are not having any luck with that pachyderm! hopefully it is just a plug - definitely not the result you want when priming !
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: DoubleD] #2388149
10/16/17 01:47 PM
10/16/17 01:47 PM
PA.
"Little"John
"Little"John
PA.
I'm so glad you are finally getting a fresh set of eyes on your engine. I know he's your friend but man you have had some issues for the ET's you are going. Good luck and I too hope it's a simple issue
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: pittsburghracer] #2388407
10/16/17 09:46 PM
10/16/17 09:46 PM
Dragula Offline OP
Dragula  Offline OP
Over the years, I have not had a lot of luck with aftermarket blocks it seems.
So even if I get it right, unless I fully cage the car, its more than I need. But it would be nice to have it running again.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2422070
12/21/17 10:52 PM
12/21/17 10:52 PM
Dragula Offline OP
Dragula  Offline OP
So....Its back!!!
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2422090
12/21/17 11:27 PM
12/21/17 11:27 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Looks good, Randy. What was the cause of the low oil pressure? Are you waiting until next spring to fire it up?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: DusterDave] #2422092
12/21/17 11:35 PM
12/21/17 11:35 PM
Dragula Offline OP
Dragula  Offline OP
A couple of badly used fittings, a leaky suction hose, and, for some reason, the brand new oil pump.
Going to try and put it in the car this weekend. Start it up when we get a real nice warm day...
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2422140
12/22/17 01:06 AM
12/22/17 01:06 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Originally Posted By Al_Alguire
Whats up with that oil filter???
Its a K&P Engineering re-usable filter. I have a couple of them I bought from Ray Bartons shop. I like these a lot better than others I have used.
And sanwhiched between the Milidon pump & cover and the oil filter is an adapter to go to my Accumulator
Just curious, was this filter on the engine when you had problems each time?
Or is it a new addition since the rebuild?
I have always been a believer in the more gimmicks, the more things can go wrong. Less is better for me.
Good luck and I can't wait for you to get it going again. I really enjoyed the U tube races you posted.
Old Geezer Racing
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2422166
12/22/17 01:42 AM
12/22/17 01:42 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
What an adventure! I hope it's right this time!!!
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: gsmopar] #2422178
12/22/17 02:00 AM
12/22/17 02:00 AM
PA.
"Little"John
"Little"John
PA.
Throw some salt over your right shoulder and find a few four leaf clovers. Did you use the same engine builder
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: pittsburghracer] #2422221
12/22/17 08:42 AM
12/22/17 08:42 AM
Dragula Offline OP
Dragula  Offline OP
No...different engine builder. He says I post to much on the interweb, so I have to keep it short.
