Re: Guesses on E.T and M.P.H 426 hemi [Re: CSK] #2387424
10/14/17 05:59 PM
10/14/17 05:59 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
What intake and carb(s)?
Re: Guesses on E.T and M.P.H 426 hemi [Re: polyspheric] #2387425
10/14/17 06:03 PM
10/14/17 06:03 PM
MI
MI Mopar Works Offline OP
MI
Originally Posted By polyspheric
Where does the 600 hp come from?
Its a well thought out combo built for factory stock deag racing. I could go into great detail, but a 11.5:1 426 Hemi with a modern designed camshaft with heads that flow over 375 cfm better be making those kinda numbers in my opinion.
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: Guesses on E.T and M.P.H 426 hemi [Re: Lee446] #2387426
10/14/17 06:05 PM
10/14/17 06:05 PM
MI
MI
Its a stocker , so it uses a factory inline 2x4 chrysler intake and a set off factory carter afb carbs.
Parts Sales
Re: Guesses on E.T and M.P.H 426 hemi [Re: Cab_Burge] #2388098
10/16/17 12:26 PM
10/16/17 12:26 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Originally Posted By Cab_Burge
13.00+ ET and 115+ MPH if you can get it to leave halfway decent twocents
The seasoned bias ply tires being the limiters shruggy
That's about what I'm expecting.
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2388357
10/16/17 08:27 PM
10/16/17 08:27 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
It doesn't take much to put a Hemi into the twelves. It will run mid to high twelves. A Hemi has a big high gear, should run 112-115mph.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2388625
10/17/17 10:55 AM
10/17/17 10:55 AM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
I have no doubt it makes 600 HP and It will run in the tens even with "seasoned bias ply tires" - just go watch Dudek run in the high nines with a worn out set of polyglas tires! fricking nutz but it works!
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2389454
10/18/17 07:03 PM
10/18/17 07:03 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
This is easy...11.99 at 117.5
Ask me how I know
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2389518
10/18/17 09:23 PM
10/18/17 09:23 PM
MI
MI
Hopefully I will have an answer to this question and we will see how close some of you came, but it will have to wait at least until next month.
Parts Sales
Re: Guesses on E.T and M.P.H 426 hemi [Re: DoubleD] #2389536
10/18/17 09:41 PM
10/18/17 09:41 PM
jersey
Spaceman Spiff Offline
jersey
That combination is made to work around those tires. That's why it works so well. That chassis/suspension may "look" stock, but it's far from it.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Guesses on E.T and M.P.H 426 hemi [Re: Spaceman Spiff] #2389554
10/18/17 10:08 PM
10/18/17 10:08 PM
NE Ohio
NE Ohio
it still has leaf springs - I have the dana out the car now under my car before he switched to the 8-3/4 - it not as trick as you think - its how its driven and how much weight is the trunk of the car - the car on the other hand - was well thought out -light weight is the theme and every ounce counts combined with brute high rpm horsepower. Dudek is the master of the class and it shows
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2389723
10/19/17 09:14 AM
10/19/17 09:14 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Is the car set up to work off the line with those tires?
Does the driver have experience getting off the line with a traction-limited combination?
drive
