LM-2 single or dual O2 sensor, which to get? #238700
02/28/09 11:29 AM
02/28/09 11:29 AM
Kewaskum, WI
K
Kelob_pie Offline OP
K
Kewaskum, WI
Hi guys, I will be buying an LM-2 in the next month or so, is it worth it to get the one with the dual O2 sensors, or should I just save the xtra $200 and get the one with the single sensor? Thanks for any input!
Re: LM-2 single or dual O2 sensor, which to get? [Re: Kelob_pie] #238701
02/28/09 11:49 AM
02/28/09 11:49 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
There is more cylinder to cylinder variance than bank to bank, so you'll be fine with a single. The advantage of 2 is really for either averaging both banks, or seeing if you have trouble with one side or the other. Not very common with carbs, but it happens with injection. I use 2, but more often than not really don't need both signals.
Re: LM-2 single or dual O2 sensor, which to get? [Re: dthemi] #238702
02/28/09 11:56 AM
02/28/09 11:56 AM
KY
juicedcuda Offline
juicedcuda  Offline
KY
so to run the single sensor do you just use one bung on either collector of choice?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
