I'm getting better at this sheet metal stuff #2374053
09/20/17 07:23 PM
09/20/17 07:23 PM
AndyF Offline OP
AndyF  Offline OP
I needed a way to hang my ignition and vacuum pump chamber off the engine so I decided to try making the bracket from one piece of sheet metal. I went with a 12 ga SST so it would look good without any painting or plating.
Pictures show the raw part then bending the part, installing the nuts and the finished part.
DSC_1250 (Large).JPGDSC_1255 (Large).JPGDSC_1259 (Large).JPGDSC_1262 (Large).JPG
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374054
09/20/17 07:24 PM
09/20/17 07:24 PM
AndyF Offline OP
AndyF  Offline OP
Here it is installed on the engine with the ignition box, coil and vacuum pump chamber all bolted in place.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374056
09/20/17 07:26 PM
09/20/17 07:26 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Nicely done.
Clean idea.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374081
09/20/17 08:12 PM
09/20/17 08:12 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Very nice!
Do you like that big coil? I run one with my 7AL2 and in retrospect would have bought a smaller one. Always ran 0.042 inch spark plug gap and didn't change it with the new coil. Burned up about half a dozen nice Accel caps because the inner electrode burned up. Ended up having to reduce the plug gap to 0.030 to prevent cap failures.
I just don't need that much energy..........
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374107
09/20/17 08:40 PM
09/20/17 08:40 PM
AndyF Offline OP
AndyF  Offline OP
I've never had any issues with this coil and I've run it for at least 10 years on all of the dyno engines.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374216
09/20/17 11:39 PM
09/20/17 11:39 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Very nice!
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374313
09/21/17 01:26 AM
09/21/17 01:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
As always, you are a class act and your work reflects the same.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374319
09/21/17 01:31 AM
09/21/17 01:31 AM
P
Porter67 Offline
Porter67  Offline
P
You be a crafty fella!
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374354
09/21/17 06:53 AM
09/21/17 06:53 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Very nice!
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374477
09/21/17 01:10 PM
09/21/17 01:10 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Are those PEM nuts! Very professional.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374489
09/21/17 01:32 PM
09/21/17 01:32 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
What spark plug gap do you set the plug for?
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374491
09/21/17 01:34 PM
09/21/17 01:34 PM
AndyF Offline OP
AndyF  Offline OP
Yes, I press in the PEM nuts since that is a good way to attach things to sheet metal. With the PEM nuts you don't have to access the back side of the part with a wrench so you can pack things together tighter. PEM nuts are inexpensive and easy to install but you do need the right equipment.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374569
09/21/17 03:31 PM
09/21/17 03:31 PM
dogdays Offline
dogdays  Offline
That's just sick!
R.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2374645
09/21/17 05:48 PM
09/21/17 05:48 PM
AndyF Offline OP
AndyF  Offline OP
I also just bent up a pair of brackets for the racing seat in my Duster. It is nice having a hyd brake out in the shop so I can bend this stuff. The laser cutting shop is just up the road and they cut parts for me with a 4 or 5 day lead time so that isn't too bad.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2385327
10/10/17 10:39 PM
10/10/17 10:39 PM
AndyF Offline OP
AndyF  Offline OP
I was able to bend up a new throttle bracket today for my EFI engine. The regular throttle brackets do not fit with the fuel rails so I built one that came off the carb studs. It needed a Z bend and a twist to clear everything.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2385412
10/11/17 01:08 AM
10/11/17 01:08 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I wish I had the tools and skill to do that.
Re: I'm getting better at this sheet metal stuff [Re: Kern Dog] #2385427
10/11/17 01:58 AM
10/11/17 01:58 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
That's a common thought of mine as I peruse through these threads. Very nice work...
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2385436
10/11/17 02:41 AM
10/11/17 02:41 AM
P
Porter67 Offline
Porter67  Offline
P
That crafty fella never rests.
Re: I'm getting better at this sheet metal stuff [Re: AndyF] #2385449
10/11/17 03:14 AM
10/11/17 03:14 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Andy, what did that press brake cost and what brand is it? I am looking at a 60 ton for some home projects!
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: I'm getting better at this sheet metal stuff [Re: Fat_Mike] #2385544
10/11/17 11:58 AM
10/11/17 11:58 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Times 3.
Great looking stuff there Andy. up
I have mechanical Aptitude.
I can screw up anything.
