Re: 451 - Valley Pan?
[Re: 80fbody]
#2384615
10/09/17 06:40 PM
10/09/17 06:40 PM
Posts: 31,203 Oregon
AndyF
Searched back a couple years but couldn't find anything on a valley pan for a low deck that works well with Edelbrock RPM heads. I have the Felpro bathtub I could use or mod. Would really prefer a thick aluminum piece like Indy's use. Looks like I'd have to fab that myself which is a possibility but really like to buy a proven one that won't leak and allow me to just use regular intake gaskets. What you are looking for does not exist and will not ever exist.
[Re: AndyF]
#2384734
10/09/17 09:37 PM
10/09/17 09:37 PM
Posts: 596 Mass.
80fbody
Mass.
Searched back a couple years but couldn't find anything on a valley pan for a low deck that works well with Edelbrock RPM heads. I have the Felpro bathtub I could use or mod. Would really prefer a thick aluminum piece like Indy's use. Looks like I'd have to fab that myself which is a possibility but really like to buy a proven one that won't leak and allow me to just use regular intake gaskets. What you are looking for does not exist and will not ever exist. Well I may have to have one made for me on a CNC.
[Re: 80fbody]
#2384760
10/09/17 10:28 PM
10/09/17 10:28 PM
dartman366
Mt. Vernon, Ohio
I put Andy's plate and batwing set-up on my 512 lo deck and to tell you the truth it is a very nice way of doing it and the best part is,,,,,no leaks, very sturdy and looks great, I highly reccomend it.
[Re: dartman366]
#2384772
10/09/17 10:40 PM
10/09/17 10:40 PM
Posts: 596 Mass.
80fbody
Mass.
T I put Andy's plate and batwing set-up on my 512 lo deck and to tell you the truth it is a very nice way of doing it and the best part is,,,,,no leaks, very sturdy and looks great, I highly reccomend it. Thanks. Wasn't sure about that setup. Thanks for that. Andy does produce nice stuff for sure.
[Re: 80fbody]
#2384811
10/09/17 11:36 PM
10/09/17 11:36 PM
AndyF
Searched back a couple years but couldn't find anything on a valley pan for a low deck that works well with Edelbrock RPM heads. I have the Felpro bathtub I could use or mod. Would really prefer a thick aluminum piece like Indy's use. Looks like I'd have to fab that myself which is a possibility but really like to buy a proven one that won't leak and allow me to just use regular intake gaskets. What you are looking for does not exist and will not ever exist. Well I may have to have one made for me on a CNC. A CNC can't make something that can't be designed. If you look at a set of RPM heads mounted on a block you'll see that there isn't any place for a billet valley plate to seal to the head.
[Re: 80fbody]
#2384965
10/10/17 10:29 AM
10/10/17 10:29 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
I have not tried to do what the OP wants, but I'm thinking it's similar to what I've done on my hemi. Using an Indy valley tray and Indy intake on regular MP heads. The heads don't overlap onto the valley cover like the Indy heads do, it just leaves a slight gap in the V groove where they meet. Fill the gap w/ a bead of silicone, then you can set the intake gaskets on w/ the intake. Some people may not like the amount of silicone needed, but it does work.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2385066
10/10/17 01:11 PM
10/10/17 01:11 PM
AndyF
I have not tried to do what the OP wants, but I'm thinking it's similar to what I've done on my hemi. Using an Indy valley tray and Indy intake on regular MP heads. The heads don't overlap onto the valley cover like the Indy heads do, it just leaves a slight gap in the V groove where they meet. Fill the gap w/ a bead of silicone, then you can set the intake gaskets on w/ the intake. Some people may not like the amount of silicone needed, but it does work. Yes you can do that. The billet valley cover will leave a v notch on each side which can be filled in with RTV. This works better if the engine has pan vacuum than if it has a lot of blowby. With pan vacuum the RTV gets sucked into the V groove and seals up. If it is a street engine and it has blowby then the pan pressure will blow the RTV out over time since there is nothing to hold it there. That is the whole idea of the batwings. The batwings are thin aluminum but that is all that is needed to reinforce the RTV.
[Re: AndyF]
#2385089
10/10/17 02:13 PM
10/10/17 02:13 PM
Posts: 596 Mass.
80fbody
Mass.
I have not tried to do what the OP wants, but I'm thinking it's similar to what I've done on my hemi. Using an Indy valley tray and Indy intake on regular MP heads. The heads don't overlap onto the valley cover like the Indy heads do, it just leaves a slight gap in the V groove where they meet. Fill the gap w/ a bead of silicone, then you can set the intake gaskets on w/ the intake. Some people may not like the amount of silicone needed, but it does work. Yes you can do that. The billet valley cover will leave a v notch on each side which can be filled in with RTV. This works better if the engine has pan vacuum than if it has a lot of blowby. With pan vacuum the RTV gets sucked into the V groove and seals up. If it is a street engine and it has blowby then the pan pressure will blow the RTV out over time since there is nothing to hold it there. That is the whole idea of the batwings. The batwings are thin aluminum but that is all that is needed to reinforce the RTV. That makes sense.
[Re: 80fbody]
#2385094
10/10/17 02:21 PM
10/10/17 02:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you use Great Stuff it will firm up harder than just silicone.. but it can be a PITA to get apart.. but on a manifold you should be able to
[Re: AndyF]
#2385199
10/10/17 06:01 PM
10/10/17 06:01 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
This is what it looks like before you start filling in with RTV. You can't go very deep with the RTV since the intake manifold needs to seal around ports. Not to mention the fact that some intake manifold gasket flanges extend below the deck surface of the head.
