Re: 451 - Valley Pan? [Re: fast68plymouth] #2385222
10/10/17 06:58 PM
10/10/17 06:58 PM
AndyF Offline
AndyF  Offline
Originally Posted By fast68plymouth
Originally Posted By AndyF
This is what it looks like before you start filling in with RTV. You can't go very deep with the RTV since the intake manifold needs to seal around ports.
Not to mention the fact that some intake manifold gasket flanges extend below the deck surface of the head.
Correct, some intake manifolds will not work with the batwings I make. I ran into an old tunnel ram that had really large flanges on it that wouldn't fit until the flanges were trimmed down.
Once you tip over the first domino in the custom part chain you don't always know where the last domino is going to land....
Re: 451 - Valley Pan? [Re: Dave Hall] #2385247
10/10/17 07:58 PM
10/10/17 07:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Originally Posted By Dave Hall
I just used the factory style pan and the right stuff, no gaskets. painted it with the engine. It has always worked great on any B-RB I've ever had.
For non-raised runner heads, that's all I've ever used as well.
Re: 451 - Valley Pan? [Re: 80fbody] #2385253
10/10/17 08:14 PM
10/10/17 08:14 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
True my Indy heads use the Indy pan but otherwise...
Re: 451 - Valley Pan? [Re: 80fbody] #2385255
10/10/17 08:17 PM
10/10/17 08:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
Std port SR's, EZ's, Victors, Pro Comp Victor copies, stg 6 heads, etc
