Re: NASTY MISFIRING / 95 CONCORDE
[Re: gtx6970]
#2384704
10/09/17 08:47 PM
10/09/17 08:47 PM
Posts: 10,647 S.E.Ohio
Magnumguy
S.E.Ohio
Advance AZ its free to scan codes.Wont be as good as reading data but its a starting point.Rocky Being a '95,will they still be able to? Most it seems won't do a 95 and back? Doubt it, OBD1 cars the connector was manufacture specific and not likely these stores will have the equipment [/quote] Thought so.
[Re: Magnumguy]
#2384747
10/09/17 10:00 PM
10/09/17 10:00 PM
Magnumguy
S.E.Ohio
It was during the work, clock was off, and I think it went dead on them while there.
[Re: Magnumguy]
#2385942
10/11/17 10:43 PM
10/11/17 10:43 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The biggest problem I saw with them was plug wires. Also make sure the plugs are ok as with 100,000 mile plugs I used to get them missfiring at 80,000 miles many times. Normally if the fuel pump is going bad it wont just feel like a missfire but will backfire and feel like the car is laying over and running out of gas. Or it will just stop running. Have someone who knows how to read a scanner check it as they can look at the adaptive fuel readings and tell if its has been running lean which is another way I could tell if the car had a fuel starving problem. But the way you desribe it to me it sounds like plugs or plug wires. Good luck , Ron
