More Milidon oiling questions. #238178
02/27/09 07:23 PM
02/27/09 07:23 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I didn't want to take away from Cabs post, but had a couple questions.I have a Milidon oil pump, but may not be able to use the port/fitting at the pump. It is a dual line system, with various parts. I'll show a couple pics, but my question is, does it matter which combo of fittings you use? Can I use the one off the pump, and one off the filter adaptor? Could I use the one on the Indy block next to the oil pump(pic#2), and the one off the filter adaptor? How about both fittings off the filter adaptor? Thanks as always,Dave.
Re: More Milidon oiling questions. [Re: 4404dart] #238179
02/27/09 07:24 PM
02/27/09 07:24 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
#2
Re: More Milidon oiling questions. [Re: 4404dart] #238180
02/27/09 07:38 PM
02/27/09 07:38 PM
AndyF Offline
AndyF  Offline
The basic concept with a dual inlet system is to feed both sides of the oil pump. So as long as you're using one inlet on each side of the pump you should be fine. Take the pump apart and study it and you'll see what I mean by feeding each side of it.
Re: More Milidon oiling questions. [Re: AndyF] #238181
02/27/09 08:20 PM
02/27/09 08:20 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
im only using a single line, the one at the rear of the pump, i use a stock regular pump also, no HV, and my motor is apart right now, bearings looks amazingly well....the pic looks right though
....BAD A$$ STREET CAR.....
Re: More Milidon oiling questions. [Re: AndyF] #238182
02/27/09 09:07 PM
02/27/09 09:07 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Ok, thanks for the input.The port on the block itself is a good workable place to have a inlet though, correct?
Re: More Milidon oiling questions. [Re: n20mstr] #238183
02/27/09 09:09 PM
02/27/09 09:09 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Thanks Tony. I had a single line, and the bearings looked great also. Thought I needed the dual line? Thanks.
Re: More Milidon oiling questions. [Re: 4404dart] #238184
02/27/09 09:25 PM
02/27/09 09:25 PM
NJ
440challenger Offline
NJ
I've been running the single line setup for years..problem i have is it takes a bit to get up oil pressure. I've tried routing the line differently too.
Re: More Milidon oiling questions. [Re: 4404dart] #238185
02/27/09 10:35 PM
02/27/09 10:35 PM
NY VA USA
GTXbound Offline
GTXbound  Offline
NY VA USA
I'm not trying to hijack here, but what kinda oil pump front cover is that? Who makes it? I'm looking to buy one just like it. Thanks!!!
Re: More Milidon oiling questions. [Re: GTXbound] #238186
02/27/09 10:42 PM
02/27/09 10:42 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
Check out Cabs post " Dual line Milidon oiling system". It's a billet part that isn't made anymore(so I hear), but there are options to this one. Good luck.
Re: More Milidon oiling questions. [Re: 4404dart] #238187
02/27/09 10:50 PM
02/27/09 10:50 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
maybe if there was a big enough demand they would make a run of them, that cover looks nice
Re: More Milidon oiling questions. [Re: 4404dart] #238188
02/27/09 11:00 PM
02/27/09 11:00 PM
AndyF Offline
AndyF  Offline
Yes, the front of the block is a good place for the inlet but I think your Milodon pump blocks off that inlet. Take your pump apart and look at it.
I designed a pump to work with the World block's front pickup location but I haven't built any yet.
Re: More Milidon oiling questions. [Re: AndyF] #238189
02/27/09 11:06 PM
02/27/09 11:06 PM
jamesc Offline
jamesc  Offline
every external feed milodon pump i've ever seen would block that feed
Re: More Milidon oiling questions. [Re: jamesc] #238190
02/27/09 11:52 PM
02/27/09 11:52 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I will also suggest a non by-pass oil filter.Throw that fram ship in the gu-bage! I use the moroso filters on my duel filter set up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: More Milidon oiling questions. [Re: hemi-itis] #238191
02/27/09 11:57 PM
02/27/09 11:57 PM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
The fram filter is there for mockup only. I have been using WIX racing filters. I agree with you
Re: More Milidon oiling questions. [Re: AndyF] #238192
02/28/09 12:02 AM
02/28/09 12:02 AM
Colorado,U.S.A
4404dart Offline OP
4404dart  Offline OP
Colorado,U.S.A
I'll look at the pump as suggested. I agree the Milidon pump will be in the way if using the fitting on the block. I am having fitment issues with the radiator hose, and headers I built, so I'm trying to come up with more options, and thus the reason for the post. I would use one or the other. But first I'll inspect the pump.Thanks.
Re: More Milidon oiling questions. [Re: 4404dart] #238193
02/28/09 02:20 AM
02/28/09 02:20 AM
AndyF Offline
AndyF  Offline
I'll look at the pump as suggested. I agree the Milidon pump will be in the way if using the fitting on the block. I am having fitment issues with the radiator hose...
Sneak peak from the book. Special radiator hose that clears the Milodon pump.
