More Milidon oiling questions.
#238178
02/27/09 07:23 PM
02/27/09 07:23 PM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
I didn't want to take away from Cabs post, but had a couple questions.I have a Milidon oil pump, but may not be able to use the port/fitting at the pump. It is a dual line system, with various parts. I'll show a couple pics, but my question is, does it matter which combo of fittings you use? Can I use the one off the pump, and one off the filter adaptor? Could I use the one on the Indy block next to the oil pump(pic#2), and the one off the filter adaptor? How about both fittings off the filter adaptor? Thanks as always,Dave.
Re: More Milidon oiling questions.
[Re: AndyF]
#238181
02/27/09 08:20 PM
02/27/09 08:20 PM
Posts: 4,673 On the parachute mount
n20mstr
im only using a single line, the one at the rear of the pump, i use a stock regular pump also, no HV, and my motor is apart right now, bearings looks amazingly well....the pic looks right though
....BAD A$$ STREET CAR.....
[Re: 4404dart]
#238188
02/27/09 11:00 PM
02/27/09 11:00 PM
Posts: 30,994 Oregon
AndyF
Ok, thanks for the input.The port on the block itself is a good workable place to have a inlet though, correct?
Yes, the front of the block is a good place for the inlet but I think your Milodon pump blocks off that inlet. Take your pump apart and look at it.
I designed a pump to work with the World block's front pickup location but I haven't built any yet.
[Re: 4404dart]
#238193
02/28/09 02:20 AM
02/28/09 02:20 AM
AndyF
I'll look at the pump as suggested. I agree the Milidon pump will be in the way if using the fitting on the block. I am having fitment issues with the radiator hose...
Sneak peak from the book. Special radiator hose that clears the Milodon pump.
