How durable/reliable are PerTronix Ignitor III modules?
#2381688
10/04/17 11:46 AM
10/04/17 11:46 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I've had pretty good luck with my orange box electronic ignition, same setup for probably 20 years. I did ditch the overadvanced MP distributor for a stock one and I can run 89 octane in my warmed over 360 since that swap.
I'm think about updating to a stock look flame thrower III distributor, matching epoxy filled flame thrower III coil, and stock look 7mm wires from pertronix. Mainly to add a rev limiter, hotter spark, and just to update these 20 year old parts in my car since its probably nearing the end of their service life anyway.
One thing I liked about the mopar stuff was knowing if it failed I could swap in an ECU or other parts from advance and limp home. Also prefer the stockish look for my car.
Thought about revenator for the same reasons, the FBO ECU while maybe superior looks too far from stick to me. And both require a different dizzy on top of the cost, where as the stock look petronix dizzy is all in one.
Do the pertronix parts fail often? Are there other options I should look at?
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: How durable/reliable are PerTronix Ignitor III modules?
[Re: Michael Ecks]
#2381697
10/04/17 11:59 AM
10/04/17 11:59 AM
RapidRobert
One thing I liked about the mopar stuff was knowing if it failed I could swap in an ECU or other parts from advance and limp home. Also prefer the stockish look for my car. No info on the P but I would Google it. Just me if your dist has tight bushings I would keep it & dial in the subsystems in order:initial/total/springs/vac adv) & get a hotter coil, maybe an E coil & ditch the ballast & some Firecore wires. but that would not give you a rev limiter. Are you sure you need one?
[Re: RapidRobert]
#2381705
10/04/17 12:14 PM
10/04/17 12:14 PM
Posts: 3,344 Central TX
roe
Central TX
Every reference to pertronix stuff I've ever seen has shown excellent reliability. There are some members who have been running their stuff untouched for over 10 years. I don't have the III but my pertronix setup has been on trouble free for a little longer than 5 years now. I have the level 2 with the epoxy coil. I think I've only ever seen maybe 2 people say they had a failure in the many many times pertronix has been discussed.
And if you carry a spare condenser and points set in the glove box like I do you cn be back on your way in 5 minutes in the unlikely scenario that it fails.
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: 71birdJ68]
#2381745
10/04/17 01:00 PM
10/04/17 01:00 PM
roe
Central TX
The only reason I went with the epoxy is so it could mount horizontally without worry of leaking
[Re: Michael Ecks]
#2381818
10/04/17 03:02 PM
10/04/17 03:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
seems to me the OEM setup has millions of miles and hours of on the road use in every possible condition.
Pertronix doesn't.
I can get OEM parts in any town in any state in the US.
Pertronix? Who knows?
[Re: Michael Ecks]
#2382073
10/04/17 09:54 PM
10/04/17 09:54 PM
Michael Ecks
Columbus, GA
Actually the Flame Thrower Stock Look distributors come with a Mopar cap not the chevy cap like most billet ready to run set ups. Here is a link. Summit Link The horizontal mounting on an intake is the reason for the epoxy filled coil. Granted my trusty oil filled Accel coil has never leaked mounted sideways, but for a few bucks more why chance it. Sounds like overall, people's experiences have been good. And since I got a conveniently timed Summit speedcard discount in the mail yesterday I guess I will give it a shot.
