Page 2 of 3 1 2 3
Re: which 426 alum.Hemi Heads to get? [Re: 6PKRTSE] #2378332
09/28/17 03:35 PM
09/28/17 03:35 PM
an8sec70cuda Offline
Originally Posted By 6PKRTSE
I have the regular ole Mopar Performance Crate Hemi heads on my 528". They flowed around 426 as cast on our flow bench but it still made 853/697 with only 10.5:1 on pump gas, so I am happy enough with them for now.
iagree Same on my 572" hemi. Just the regular old MP (pre Edelbrock castings) aluminum heads CNC ported by MCH. Making somewhere in the neighborhood of 850 hp N/A at 11:1 on pump gas.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2378366
09/28/17 04:30 PM
09/28/17 04:30 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Originally Posted By DoubleD
here are the eddy head specific pistons - these are 13-1 customs
Who makes those? I'm gonna need a set for my eddy heads!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2378449
09/28/17 07:39 PM
09/28/17 07:39 PM
Everywhere
Lost in life Offline
Everywhere
Could you guys detail the builds of the engines that are making 750+ HP with the Eddy or mopar heads? Much appreciated. Thanks in advance.
Re: which 426 alum.Hemi Heads to get? [Re: rickseeman] #2378475
09/28/17 08:36 PM
09/28/17 08:36 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Originally Posted By rickseeman
Originally Posted By Transman
Correct me if I am wrong but the only Edelbrock hemi head needing special piston notching is the latest edelbrock head with the big intake - the exhaust has a different guide angle requiring the special notch. The earlier edelbrock head sold through Mopar Performance ( with conventional valve train oiling ) does NOT need the special exhaust notch.
Just because the valve angle is different doesn't mean that you need different pistons, or that it's going to cause you problems, etc. This isn't the 60's. Back then people would shave the heads and deck the block to get more compression. This would give you more compression but would decrease the piston to valve clearance. Most engines that people put together now are strokers. With a stroker you can get all the compression you want. Strokers take a lot less dome on the piston. Your street/strip application will probably be for pump gas and not have much dome. My guess is if you check your valve to piston clearance you will find you have a mile.
When using Victor Jr's you do have to check the intake valve to bore clearance if you are using a small bore.
Tell that to my buddy with +$2600 in two sets of pistons already, bet he throws one at you!
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2378551
09/28/17 11:31 PM
09/28/17 11:31 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
DoubleD would you mind sharing whose pistons those are and the model number. I have those same heads and will be in the market for pistons.
TIA
Re: which 426 alum.Hemi Heads to get? [Re: DUSTER_340] #2378704
09/29/17 10:16 AM
09/29/17 10:16 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
TIA
The pistons are full customs designed by Best Machine - built by CP Pistons
Re: which 426 alum.Hemi Heads to get? [Re: Lost in life] #2378722
09/29/17 11:10 AM
09/29/17 11:10 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
http://raybarton.com/parts/index.php/engines/single-plane-street-series-hemi.html
I think he uses Edelbrock heads on these.
2011 Drag Pak Challenger
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2379058
09/29/17 09:47 PM
09/29/17 09:47 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Thanks Best Machine is in my area , and I was planning on using them to do all my block work.
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2379873
10/01/17 12:31 PM
10/01/17 12:31 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have CNC ported Indy SR's on mine. No results yet.
Re: which 426 alum.Hemi Heads to get? [Re: Lost in life] #2379931
10/01/17 02:02 PM
10/01/17 02:02 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Here is mine - should have dyno results very soon
https://www.facebook.com/pg/bestmachineracingengines/photos/?tab=album&album_id=1460586160663729
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2380143
10/01/17 07:27 PM
10/01/17 07:27 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
DD, that is a thing of beauty there!
HEMI,S ARE FOREVER!!!
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2380210
10/01/17 09:34 PM
10/01/17 09:34 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I'll be looking forward to seeing the results on that one! What's the cam specs?
Re: which 426 alum.Hemi Heads to get? [Re: Lost in life] #2380501
10/02/17 11:58 AM
10/02/17 11:58 AM
572" hemi, KB block, MP heads cnc'd by MCH
11:1 CR for pump gas, Callies crank, Oliver steel rods, Diamond pistons
276°/284° at .050", .672"/.651" lift solid roller. Very mild lobes to be easy on parts.
DLI roller rockers, Barton single 4500 intake, 1200 cfm dominator
Has run 9.54 at 140.4 mph at 3800+ lbs. on just the motor and pump gas. Somewhere in the 850 hp ballpark.
CHIP
Re: which 426 alum.Hemi Heads to get? [Re: DoubleD] #2383351
10/07/17 12:04 PM
10/07/17 12:04 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Dyno results are in
https://www.facebook.com/bestmachineraci...ZvhhNwjJ8ZQX3W4
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2383484
10/07/17 04:55 PM
10/07/17 04:55 PM
Everywhere
Everywhere
Not to be crass...but approximate cost for that build?
Re: which 426 alum.Hemi Heads to get? [Re: Lost in life] #2383489
10/07/17 05:05 PM
10/07/17 05:05 PM
N.Y.
sixpacksteve Offline OP
N.Y.
Can i guess? 20k+
Hell Hath No Fury Like Mine
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2383491
10/07/17 05:18 PM
10/07/17 05:18 PM
Everywhere
Everywhere
That is probably a pretty safe bet...
Re: which 426 alum.Hemi Heads to get? [Re: Lost in life] #2383539
10/07/17 07:29 PM
10/07/17 07:29 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Speed cost money son - how fast you wanna go!
All I will say it is worth every dollar I spent - Best Machine used nothing but the best parts even on the small parts - I discussed what I wanted with Chuck before starting - it was a simple request a 572 with 800HP run on 110 fuel - using the the big valve eddy heads - 2 AFB's and the new Mega Block I had - I left everything else up to him - He delivered a big torque and durable HEMI - it could make more HP with a different intake and bigger carbs I am pretty sure of that - but I wanted in-line AFB's for NSS class racing. Overall I would say Best Machine delivered above my expectations
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2383556
10/07/17 08:16 PM
10/07/17 08:16 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What intake manifold did you end up with?
Re: which 426 alum.Hemi Heads to get? [Re: sixpacksteve] #2383561
10/07/17 08:21 PM
10/07/17 08:21 PM
Everywhere
Everywhere
Understand that. Enjoy your ride!
Page 2 of 3 1 2 3
