Re: '72 Duster ignition key and column collar
[Re: AndyF]
#2376273
09/25/17 10:07 AM
09/25/17 10:07 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Are you sure you are on OFF position and not in ACC position which is one step more back after the OFF position?
[Re: Doc Schwarz]
#2376422
09/25/17 01:12 PM
09/25/17 01:12 PM
Posts: 30,989 Oregon
AndyF
When you put it in park the collar rotates, so you are missing something under the column from the shifter or linkage under the car. Then you press the lever and turn the key back to remove it. It is a manual shift car.
[Re: AndyF]
#2376543
09/25/17 04:08 PM
09/25/17 04:08 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
It is a manual shift car. from the shifter or linkage under the car. Did you miss this part? My guess it's either there or in the clutch linkage.
I have mechanical Aptitude. I can screw up anything.
