Re: Failing alternator, truck not charging battery
[Re: a12rag]
#2377716
09/27/17 02:18 PM
09/27/17 02:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
On truck with regulator built into the computer, just add 70's style electronic regulator - requires you to rewire the field to the new regulator, and an ignition "ON" on source to the regulator. Way easier and cheaper than getting another computer . . . Day late Dollar short Welcome to the show
[Re: a12rag]
#2378246
09/28/17 01:00 PM
09/28/17 01:00 PM
RapidRobert
On truck with regulator built into the computer, just add 70's style electronic regulator - requires you to rewire the field to the new regulator, and an ignition "ON" on source to the regulator. Way easier and cheaper than getting another computer . . . That would definitely be my choice (unless the yard was close by/it was practical to do the $10 purchase situation)
