Re: My Magnafuel 275 has died
[Re: justinp61]
#2367772
09/09/17 04:53 AM
09/09/17 04:53 AM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
Been running a Aeromotive pump daily and racing the last 4 years (?) maybe . Quiet and no dramas . The one below a 1000 series . Oh i also fitted their return regulator at the same time . Went from a Holley hp150
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: rebel]
#2367853
09/09/17 11:50 AM
09/09/17 11:50 AM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
i've had a lot of luck with the Magnafuel. both my racecar & my streetcar run the 275. both have never had an issue. whats actually wrong with the pump? I don't have it off yet but it appears the motor is locked up.
[Re: justinp61]
#2367869
09/09/17 12:38 PM
09/09/17 12:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It sounds like it was fat also being that you went quicker when the pump was dying.. so after you get a pump try leaning it down EDIT I was running a pair of 140s on my stuff before I swapped to injection but 1 of them would work for you(Mallory 140)
[Re: justinp61]
#2367870
09/09/17 12:39 PM
09/09/17 12:39 PM
Posts: 26,290 United Socialist States of Ame...
tboomer
Justin...Maybe you will get lucky. A few weeks back that Holley HP 150 locked up on me. Took it apart and cleaned up the gear assembly and it works just fine! I did install an Aeromotive S/S 11203 pump that works great! It may be a bit noisy for the street. Good luck!
[Re: justinp61]
#2367881
09/09/17 01:03 PM
09/09/17 01:03 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
In the past, Magnafuel has been excellent to deal with for parts and service. I'd call them before buying a new pump.
[Re: fast68plymouth]
#2367921
09/09/17 03:04 PM
09/09/17 03:04 PM
Posts: 43,741 Bend,OR USA
Cab_Burge
[Re: justinp61]
#2368294
09/10/17 01:39 PM
09/10/17 01:39 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Get another pump... Work on the tune-up and the power management for whatever track your running.... Spinning ant winning..... I agree... Sounds too fat..
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: stevet340]
#2368469
09/10/17 08:59 PM
09/10/17 08:59 PM
justinp61
W. Kentucky
More than likely the small bearing nearest the fuel inlet and outlet froze up. I've seen 2 magnafuel pumps do this in the past 3 days... The bearing shouldn't cost more than $5-$10. DING DING DING.........We have a winner! Guys if your Magnafuel pump starts leaking replace the bottom bearing when you do new seals. It could save you some grief.
[Re: justinp61]
#2368718
09/11/17 10:54 AM
09/11/17 10:54 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
If you still decide to get another one, the Aeromotive 11203 is a real good little pump. I ran one for a long time on my car running mid 9s at 3800 lbs...just a simple deadhead system w/ -8 line.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: justinp61]
#2368785
09/11/17 01:02 PM
09/11/17 01:02 PM
Triple Threat
Renton Washington
More than likely the small bearing nearest the fuel inlet and outlet froze up. I've seen 2 magnafuel pumps do this in the past 3 days... The bearing shouldn't cost more than $5-$10. DING DING DING.........We have a winner! Guys if your Magnafuel pump starts leaking replace the bottom bearing when you do new seals. It could save you some grief. My magnafuel 300 did the exact same thing. I sent mine back to MF and they fixed it up for me.
