How to possitively ID a Dana 60 over a 61? #23736
04/17/06 07:21 PM
04/17/06 07:21 PM
bcrproducts Offline OP
super gas
super gas
Hi Guys.
The one thing I am not, and that is an expert on IDing of rearends. There seems to be so many versions of the Dana 60 over the 61. Can anyone help me possitively id this housing before I go further with this build. I will attach several pics. I know this is a general question but it will be a race rearend---thanks---Greg
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23737
04/17/06 07:22 PM
04/17/06 07:22 PM
super gas
super gas
Another 1
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23738
04/17/06 07:23 PM
04/17/06 07:23 PM
super gas
super gas
another 2
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23739
04/17/06 07:24 PM
04/17/06 07:24 PM
super gas
super gas
another 3
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23740
04/17/06 07:25 PM
04/17/06 07:25 PM
super gas
super gas
another 4
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23741
04/17/06 07:26 PM
04/17/06 07:26 PM
super gas
super gas
another 5
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23742
04/17/06 07:27 PM
04/17/06 07:27 PM
super gas
super gas
I liked this housing as it seems to be the beefiest housing I have seen as far as strutting etc.
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23743
04/17/06 08:00 PM
04/17/06 08:00 PM
Centerville, MN
schwep Offline
schwep  Offline
Centerville, MN
I have the same one and IIRC the 60HD stamp is your answer. I believe the 61's were stamped 61 and the offset of the pinion centerline is different than a 60 as well. Way thick axle tubes aren't they?
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23744
04/18/06 10:32 AM
04/18/06 10:32 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Thats the one I run and prefer.
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23745
04/18/06 12:46 PM
04/18/06 12:46 PM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
What the heck did they put a 61 in??? I've never even heard of a Dana 61 ???
As for that 60 HD, man does that look bulletproof!!! Any idea on how much heavier it is compared to run-of-the-mill 60?
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: How to possitively ID a Dana 60 over a 61? [Re: Ramcharger] #23746
04/18/06 01:24 PM
04/18/06 01:24 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Me neither
Lee
Moparlee
Re: How to possitively ID a Dana 60 over a 61? [Re: Robbins] #23747
04/18/06 01:34 PM
04/18/06 01:34 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
Use this attachemnt as a reference. I am trying to find a better chart I have that shows the whole Dana/Spicer family. Stay tuned.
Re: How to possitively ID a Dana 60 over a 61? [Re: Scamp451] #23748
04/18/06 01:53 PM
04/18/06 01:53 PM
Centerville, MN
schwep Offline
schwep  Offline
Centerville, MN
61's were used in many Ford truck and (I think) Dodge van applications. I believe they were all full-floaters and used in 3/4 ton and larger vehicles thru the mid to late 1970's. The design of the housing permitted taller axle ratios.
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23749
04/18/06 02:07 PM
04/18/06 02:07 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
That is a Dana 60 HD. We just built one for my dads challenger using that housing.
The only Carbs I care about are under the hood!
Re: How to possitively ID a Dana 60 over a 61? [Re: Azzkikrcuda] #23750
04/18/06 02:39 PM
04/18/06 02:39 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Here is a pretty complete list of Dana BOM numbers from `79-99 if yours is still there (right axle tube) there is a link to Dana`s site that will search a BOM number or part number if yours isn`t shown.
Dana BOM List
A list of some Mopar specific BOM`s
Mopar specific Dana BOM list `68-78
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
Re: How to possitively ID a Dana 60 over a 61? [Re: bcrproducts] #23751
04/19/06 12:13 AM
04/19/06 12:13 AM
Cab_Burge Online work
Cab_Burge  Online Work
The Dana 60 HD was used mostly in heavy vehicle like mini motor homes and the 3/4 ton vans that didn't have the Dana 70 in them. It is a lot heavier than the regular Dana 60s.
Re: How to possitively ID a Dana 60 over a 61? [Re: Cab_Burge] #23752
04/19/06 01:00 AM
04/19/06 01:00 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I think the 61 was also used in some C-bodies.
Dr. Diff would be the one to ask.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: How to possitively ID a Dana 60 over a 61? [Re: AlexP] #23753
04/19/06 01:17 AM
04/19/06 01:17 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Dana 53 rearends were sometimes (rarely) used in C-bodies.
Dana 61 rearends were found in some Ford 3/4 ton pickups and vans in the late '70s/early '80s.
Dana 61 front-ends were used in late '80s/early '90s Dodge diesel/automatic 4x4 pickups.
Re: How to possitively ID a Dana 60 over a 61? [Re: DoctorDiff] #23754
04/19/06 07:45 AM
04/19/06 07:45 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I have bin offered a Dana 60 ??? it only has 2-3/4 tubes could this be a 60 ? and is it ok to build a spool rear with.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: How to possitively ID a Dana 60 over a 61? [Re: wildcargo] #23755
04/19/06 08:02 AM
04/19/06 08:02 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
When I was looking for a Dana 60 housing in a local bone yard, a few years ago. I saw one of that style housing under a late 70's Dodge "Snow Commander", 4 x 4 pickup. I had never seen one gusseted like that either.
