Thanks PTC #2373461
09/19/17 06:40 PM
09/19/17 06:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
For making my converter fit better,Pilot cut down to stick out .150 past the bolt tab from .225,adjusted pump drive length/ht to not bottom in the pump,welded,tapped stripped bolt hole,stall adjustment from 5500 to 5k.
Getting to this point has been a challenge after another converter company could not make a new cert to fit after 2 cores and I got my $$ back and had the old PTC fixed.Now to get this in the car again.
Re: Thanks PTC [Re: Clanton] #2373556
09/19/17 09:14 PM
09/19/17 09:14 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
up PTC has been my go-to converter company for nearly 20 years. Nothing but good things to say about them.
Master, again and still
Re: Thanks PTC [Re: Clanton] #2373672
09/20/17 12:08 AM
09/20/17 12:08 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Good luck!Want to see ZOOOOOOM
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
