Big Block Supra #237338
02/26/09 08:01 PM
02/26/09 08:01 PM
Hampton,Va
Q
QuickDart 502 Offline OP
Q
Hampton,Va
I got a friend of mine whos got a 1988 supra thats looking to put a 383 into, has anyone tried this swap? It appears there is enough room in the engine compartment and it also has a pretty large transmission tunnel. It looks like a truck oil pan would be the ticket for clearing the rack.
Re: Big Block Supra [Re: QuickDart 502] #237339
02/26/09 08:32 PM
02/26/09 08:32 PM
Sounds like the perfect, logical answer to the 69 Camaro in the new Hotrod mag with a Supra turbo motor in it!!!
Pete
Re: Big Block Supra #237340
02/26/09 09:16 PM
02/26/09 09:16 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Isn't the Supra's eng compartment larger than a Daytona,Reliant,Avenger,etc?? Do it and show the pics. I think it'd be pretty cool. Give some back to the GM guys that put their motors in everything.
fwiw, I have a 440 in my Dak and used a truck pan to clear my front cross member and rack..I just had to modify my pick up tube and windage tray. I already had these. Not positive whats available..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Big Block Supra [Re: KatFysh] #237341
02/26/09 09:52 PM
02/26/09 09:52 PM
Hampton,Va
Q
Q
Hampton,Va
after more ivestigating it appears the only real obsticle will be fabricating the headers. iv eseen a couple of sbc conversions with twin turbos slung down low in the engine compartment, if that will fit i believe a 383 will.
Re: Big Block Supra [Re: QuickDart 502] #237342
02/26/09 10:51 PM
02/26/09 10:51 PM
Chicagoland
chargerron69 Offline
Chicagoland
it shouls work out good, im planning on doing a 97 240sx with a big block and viper six speed.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
