Re: Has anyone here used cast metal engine paint?
[Re: 1970RT]
#2372735
09/18/17 02:31 PM
09/18/17 02:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use the hammered finish on a lot of my stuff which has a look of cast but shiner.. I like it (rustoleom)spray paint EDIT I'll try to get some pics... looks like this pretty much
[Re: MR_P_BODY]
#2373208
09/19/17 11:09 AM
09/19/17 11:09 AM
Posts: 19,336 north of coder
moparx
I use the hammered finish on a lot of my stuff which has a look of cast but shiner.. I like it (rustoleom)spray paint EDIT I'll try to get some pics... looks like this pretty much mr. P, i've used the rustoleum hammered paints before, but get mixed results. i have done several wheels that were pitted badly, but turned out pretty good because they were laying flat, and i could lay the paint on in a somewhat controlled manner, getting a uniform pattern. but when i have tried to shoot something like your heater box shown, the pattern seems inconsistent. any tips you can share ? the other item i find is the paint seems kind of "soft", unless it dries for months and months before putting into service. is this normal ?
[Re: moparx]
#2373245
09/19/17 12:14 PM
09/19/17 12:14 PM
MR_P_BODY
I use the hammered finish on a lot of my stuff which has a look of cast but shiner.. I like it (rustoleom)spray paint EDIT I'll try to get some pics... looks like this pretty much mr. P, i've used the rustoleum hammered paints before, but get mixed results. i have done several wheels that were pitted badly, but turned out pretty good because they were laying flat, and i could lay the paint on in a somewhat controlled manner, getting a uniform pattern. but when i have tried to shoot something like your heater box shown, the pattern seems inconsistent. any tips you can share ? the other item i find is the paint seems kind of "soft", unless it dries for months and months before putting into service. is this normal ? More than likely you are putting on to thick..but if you put on multi coats it will change the color also.. I like to use 2 coats 3 at max and let each coat dry before adding the next coat.. I've painted my last 3 engines with it and I like the color and the way it comes out... one of the things is the distance you hold the can.. try a couple of different distances to see how it does
[Re: 1970RT]
#2373403
09/19/17 04:48 PM
09/19/17 04:48 PM
Posts: 427 Sweden
Mopar Guy
Sweden
I only use real car paint 2K and start whit a strong epoxy primer but it needs to be SUPER clean before you start painting !
