Re: Locked Dizzy and starting ?
[Re: Kindafast]
#2372976
09/18/17 09:52 PM
09/18/17 09:52 PM
Posts: 4,219 New York
polyspheric
New York
Leaving out starter-kickback as solvable: what engine idles better with full advance than partial advance? Engines that idle above 2,000 RPM.
Boffin Emeritus
[Re: Kindafast]
#2373001
09/18/17 10:28 PM
09/18/17 10:28 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
1500 with light springs? The advance is just about all in anyway. Try 800, with a big roller, in gear at 18 degrees initial.
[Re: Kindafast]
#2373211
09/19/17 11:14 AM
09/19/17 11:14 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
I've never had an issue cranking my 14.5:1 446" wedge or my 11:1 572" hemi w/ locked out timing. As long as your battery, starter, and the wiring b/t the 2 are good, you should be fine. Glad you found the issue!
Guess everyone running a crank trigger doesn't know how to tune a motor. LOL, gimme a break.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: polyspheric]
#2373246
09/19/17 12:14 PM
09/19/17 12:14 PM
DaytonaTurbo
Manitoba, Canada
Leaving out starter-kickback as solvable: what engine idles better with full advance than partial advance? Engines that idle above 2,000 RPM. What engine idles worse with full advance at idle? Even my stock lo-po 440 idled great with full advance at 700rpm idle when I tried it just for fun.
[Re: Kindafast]
#2373526
09/19/17 08:13 PM
09/19/17 08:13 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Thanks again guy's , I have been racing a long ass time but never thought of the ignition cutoff switch. Duhh LOL . I installed a manual MSD switch this afternoon and it works great. Damn toggle switches all over my car but it works great. I really think the main issue was the battery. It is funny how it still holds 12.7 volts but you can tell it is weak spinning my engine over. I put another high amp battery in it and it spins over great. Everything wears out I guess !!
6.50 @105.26
[Re: 70dusterjohn]
#2373607
09/19/17 10:28 PM
09/19/17 10:28 PM
RapidRobert
How do you wire one to turn over and the ignition switch ? A seperate normally closed switch in series with the ign (blue/yellow ECU main feed wire works for this). Press it to disable the ign/crank with the key/let your thumb off of it while still cranking.
[Re: 540challenger]
#2373667
09/20/17 12:00 AM
09/20/17 12:00 AM
Thumperdart
State of confusion
I run 2 Orbital gel batteries and one is from 07 and still rocks........... off topic. I love my orbital however they are no longer being made. 😨 I heard you can get em on line but never checked......
