Hood pin lanyard location #2372120
09/17/17 11:17 AM
09/17/17 11:17 AM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Saw a nice v code 70 superbee at a show today.In front of the hood pins in the bracket, there was a 1/4 to 3/8 hole which the lanyard ran through and then down and through a gap of
the headlight bezel and front panel....NOT on top of the sheetmetal..Is this correct???
Re: Hood pin lanyard location [Re: 70RR383] #2372692
09/18/17 01:26 PM
09/18/17 01:26 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
subscribed... I would like to know the answer as well.
Re: Hood pin lanyard location [Re: 70RR383] #2372751
09/18/17 02:48 PM
09/18/17 02:48 PM
between the coasts
4mayhemi Offline
4mayhemi  Offline
between the coasts
I'm not sure I understand your description, especially "top of sheetmetal".
The lanyard end eyelet is screwed into the fender flange extension (this "sheetmetal"?), then kinda hangs off the side of that flange and routes under the upper bumper support, through the gap between the bumper/grille.
The factory hole in the fender flange extension the size you indicate is 2" from where the lanyard screws, so if you routed it down this hole (instead of hanging it off the side) it would be on the "sheetmetal" for 2" worth.
Depending on the alignment of the fender and rubber pad underneath, this hole could slightly overlap the upper bumper support, so if they intended the lanyard to route through here it could have some really sharp bends.
Hijacked drawings from another thread here, shows bent lanyard, but no hole, and no specific instructions to route through the hole.
