Front axle changes #2371584
09/16/17 02:49 AM
09/16/17 02:49 AM
Mi.
G-Money1320 Offline OP
Mi.
Can I put older style straight axles in my housing with the vacuum pod setup for engaging the 4 wheel drive? If so would I have to remove the vacuum setup and make a block off plate? I believe the axle I am referring to is 1985 and up and want to use my 83 axles. Thanks. Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Front axle changes [Re: G-Money1320] #2371614
09/16/17 08:01 AM
09/16/17 08:01 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The oil seal for the long shaft is in a different spot. Not sure if the newer housing is macined for the inner seal on the old shaft.
Could of course just do a permanent lock changeover on the cad system.
You can swap the whole axle easy as long as ratios match.
Angry white pureblood male
Re: Front axle changes [Re: ruderunner] #2371686
09/16/17 01:28 PM
09/16/17 01:28 PM
Mi.
Mi.
I was hoping to switch to a 3.23 gear but don't want to use the cad system since my truck doesn't have the vacuum setup. I might just have to swap the gears out from the housings which was my worst case scenario or just keep the 3.55's. I never thought the seal would be the difference. I'm going to put an 8 3/4 in the rear so I have 2 choices here. Thanks.
Re: Front axle changes [Re: G-Money1320] #2371732
09/16/17 03:16 PM
09/16/17 03:16 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Locking the CAD is about as simple as falling off a wet log.
Sheldon
