Re: Oil line size
[Re: kevinlc]
#2371792
09/16/17 05:50 PM
09/16/17 05:50 PM
Posts: 31,049 Oregon
AndyF
I'm thinking that at .030 per lifter equals .480 which is right at half an inch so the main line to the distribution block should be a -8 or is that to big? No you have to add the areas not the diameters. If you have a 0.030 hole for each lifter then that is only 0.0007 sq inch per lifter. 16 of those is 0.0113 sq inches which is the same as a 0.120 line.
