shifter mount ? #2371180
09/15/17 12:42 PM
09/15/17 12:42 PM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
i was told that this shifter set up is to put a 60's 833 in a 71 up b body with a bench seat.can anyone chime in?i'm not familar with this mount and couldn't find it on brewers.thanks for any info.
Re: shifter mount ? [Re: kdsmith07] #2371201
09/15/17 01:46 PM
09/15/17 01:46 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Don't know but I can tell you one thing, the reverse rod should be on the bottom... scope
JB Rhinehart, Realist
A-Body's RULE!
Re: shifter mount ? [Re: kdsmith07] #2371203
09/15/17 01:50 PM
09/15/17 01:50 PM
Loganville GA.
K
K
Loganville GA.
ya,i just stuck it on there for a pic,thanks
Re: shifter mount ? [Re: kdsmith07] #2371206
09/15/17 01:52 PM
09/15/17 01:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
That's home made. The factory unit was one pice casting.
Re: shifter mount ? [Re: kdsmith07] #2371213
09/15/17 02:16 PM
09/15/17 02:16 PM
Loganville GA.
K
K
Loganville GA.
idk.it looks like it was a manufactured mount for something.
Re: shifter mount ? [Re: kdsmith07] #2371246
09/15/17 03:33 PM
09/15/17 03:33 PM
dogdays Offline
dogdays  Offline
Chrysler would most likely cast a housing with the right mount for the shifter. If it was a limited run they would have probably used a stamping.
The fabricated bracket is either homebuilt by a guy with really good fabricating skills, or by a shop producing kits for the "bolt-on" modification. There is way too much welding and fitting for that to have been made by Chrysler. Plus, the welding is too good!
R.
Re: shifter mount ? [Re: dogdays] #2371251
09/15/17 03:35 PM
09/15/17 03:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have a 71 bench seat mount, and believe me that it ain't nothing like that plunder.
Re: shifter mount ? [Re: kdsmith07] #2371280
09/15/17 04:08 PM
09/15/17 04:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's all home/shop brewed, if it works, that's fine, if you want a stock set up it looks like this....
Re: shifter mount ? [Re: kdsmith07] #2371288
09/15/17 04:37 PM
09/15/17 04:37 PM
Loganville GA.
K
K
Loganville GA.
thanks for the input guys.maybe better off selling the shifter without the bracket.now i have to match up the linkage to something.thanks again
Re: shifter mount ? [Re: kdsmith07] #2371299
09/15/17 04:55 PM
09/15/17 04:55 PM
Loganville GA.
K
K
Loganville GA.
just found a set up like this on ebay.the mount and rods are for a hurst super shifter and/or ram rod shifter.
Re: shifter mount ? [Re: Rhinodart] #2372003
09/17/17 12:41 AM
09/17/17 12:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The reverse rod is on the 1-2 fork...
