Re: Mod Squad Challenger R/T
[Re: 6bblgt]
#2369185
09/12/17 01:49 AM
09/12/17 01:49 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
close but not quite
ADAM-12 "744 AEH" VS. MOD SQUAD "112 AEG"
who's the CA plate use numbers guru?
I am Those are 70 California plates. The plates are sequential starting with the letter A. Those are the real deal Some very early 70 cars were issued the older black plates starting with Z and the number order is reversed. Black would be ZZZ 999 and the Blues start 001 AAA After we blew through that sequence we reversed the sequence again 000 ZZZ --> 1 AAA 001 So 70 California cars will start with Z, A or B
[Re: Morty426]
#2369193
09/12/17 02:04 AM
09/12/17 02:04 AM
Posts: 17,514 Las Vegas, NV
6bblgt
Las Vegas, NV
close but not quite
I am Those are 70 California plates. The plates are sequential starting with the letter A. Those are the real deal Some very early 70 cars were issued the older black plates starting with Z and the number order is reversed. Black would be ZZZ 999 and the Blues start 001 AAA After we blew through that sequence we reversed the sequence again 000 ZZZ --> 1 AAA 001 So 70 California cars will start with Z, A or B & if plates were distributed sequentially - these two would be 368 1,632 vehicles apart from the same DMV office
[Re: 6bblgt]
#2369210
09/12/17 02:31 AM
09/12/17 02:31 AM
Posts: 1,674 California
biggE
California
Dan, that is to cool! Could be the same car in both shows. I might be incorrect about the Mod Squad car not having A/C. I think the A63 on both cars is a pretty good hint that the cars could be the same.
[Re: biggE]
#2369215
09/12/17 02:41 AM
09/12/17 02:41 AM
6bblgt
Las Vegas, NV
the problem is I have it hand written from I don't know where ..... but the "ODD" thing is both cars appear to have the A63 - "moulding package" which included M31 - "belt mouldings" & they're missing on both cars aren't they? a possible explanation: there are a number of late-September/early-October '69 built 'cudas that were built w/o their STANDARD M31 - "belt mouldings". I've known of the missed mouldings on the 'cudas for decades, this is the first evidence I've seen (& realized) that it was a Challenger issue also! learn something new everyday!
[Re: biggE]
#2369216
09/12/17 02:47 AM
09/12/17 02:47 AM
6bblgt
Las Vegas, NV
Dan, that is to cool! Could be the same car in both shows. I might be incorrect about the Mod Squad car not having A/C. I think the A63 on both cars is a pretty good hint that the cars could be the same. different plates, if they are using actual registered cars & plates, they wouldn't have swapped them I bet the MOD SQUAD car is no A/C & NO ROAD wheels check out the clear windshield on the air conditioned ADAM-12 car - Oh HOLLYWOOD!
[Re: 6bblgt]
#2369235
09/12/17 04:30 AM
09/12/17 04:30 AM
Morty426
Sacramento CA
close but not quite
I am Those are 70 California plates. The plates are sequential starting with the letter A. Those are the real deal Some very early 70 cars were issued the older black plates starting with Z and the number order is reversed. Black would be ZZZ 999 and the Blues start 001 AAA After we blew through that sequence we reversed the sequence again 000 ZZZ --> 1 AAA 001 So 70 California cars will start with Z, A or B & if plates were distributed sequentially - these two would be 368 1,632 vehicles apart from the same DMV office Plates are issued to offices sequentially in lots. You are correct that these plates are 1632 apart - in CA that is darn close. We go through a lot cars .... and plates
[Re: buildanother]
#2369362
09/12/17 01:03 PM
09/12/17 01:03 PM
Posts: 4,051 Connecticut
jeff968
Connecticut
Never got in to watching Mod Squad back then, but saw a re-run about a year ago, and never realized the show was so mopar heavy! One episode had some bad guy messing with Peggy Lipton? She just showed up on the Twin peaks reboot on Showtime. She was also on the series in the nineties.
1970 Dodge Challenger T/A
[Re: biggE]
#2369456
09/12/17 03:30 PM
09/12/17 03:30 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
I have the box set of the Mod Squad. They used the 1970 Challenger R/T convertible for many episodes, like 20-25. I made a note of all the options, it is misplaced for now. They have some very close up shots of it, like the radio face on the whole screen, AM-8 track. It does have A/C, power windows, rim blow, column shift. I see it does have the M31 trim on it.
There is one episode with another 70 Challenger R/T convertible. It is lime green with white top stripe interior, 15X7 rallies, polyglas tires with tire size. Has rocker mouldings, body side mouldings, front bumper guards, dual painted mirrors, painted gas cap, argent grill with R/T emblems on both fenders and the grille, no exh tips, and no moulding across the rear edge of the hood. They show it pretty good from the outside under street lights several times, can't tell interior details other than a rim blow wheel.
The 70 GTX is very cool, it was in one episode only. It's options are: bench seat, column shift, power windows, woodgrain steering wheel, FE5 red paint, black vinyl top, black reflector stripe, hood turn signals, remote drivers mirror, turndown exhaust, road wheels, polyglas tires with tires size. It has single speaker dash, but they never show a close up of the dash face to see the type of radio.
In the episode they run over some rocks and blow a tire and show up close the tire changing. They show the car with polyglas tires in every scene except the tire changing close ups it has blackwall tires, drivers side only. Looking close they blacked out the white letters, where the bottom of the tire is wadded up you can see the white letters are there and not blacked out.
They moved up to a 1971 Challenger convertible, gold with black side stripes, flat hood, light tan interior. Then it changed and it looked like the same car with 1972 grille and taillights. Then moved into a 72 or 73 Charger with a custom stripe up the one side of the hood.
