Valve Seals #2366847
09/07/17 10:30 AM
09/07/17 10:30 AM
MR_P_BODY Offline OP
I'm looking to replace my valve seals... who
makes the best.. .343 (11/32 dia)
thanks
wave
Re: Valve Seals [Re: MR_P_BODY] #2366873
09/07/17 11:42 AM
09/07/17 11:42 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
thanks
wave
What guide O.D.
What is the inner spring Diameter
All sorts of valve seals here and even more not listed
http://superformanceproducts.com/catalog.php
Re: Valve Seals [Re: roadhazard] #2366978
09/07/17 02:53 PM
09/07/17 02:53 PM
Greg.. quick question..did you ever make any
W5 intake gaskets... I see you have a 6300
and the W2 ones but I think the 6300 is a
stock 340/360.. is this true...thanks
wave
Re: Valve Seals [Re: MR_P_BODY] #2367008
09/07/17 03:43 PM
09/07/17 03:43 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
wave
W-5 intake gaskets? Who in their right mind would make those? laugh2
Yes, they are offered in .031" (#6310), .047" (#6311) and .062" (#6312) thicknesses, MicroPore-15 material thumbs
Re: Valve Seals [Re: roadhazard] #2367035
09/07/17 04:27 PM
09/07/17 04:27 PM
Works for me..can I get them thru Mancini's
wave
Re: Valve Seals [Re: MR_P_BODY] #2367147
09/07/17 07:40 PM
09/07/17 07:40 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Mike for 11/32 stems I use Comp Cams 517-16 (.500" guide) or 503-16 (.530" guide). Easy to install, they're small outer diameter, good oil control.
Doug
Re: Valve Seals [Re: MR_P_BODY] #2367153
09/07/17 08:15 PM
09/07/17 08:15 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
CompCams #529-16 here. They are setup for 0.530" valve guide diameter and 11/32 valve stem. Looks like the VITON seal material is "placed/formed" around core metal jacket.
These seals worked great for me, I went from the hard Teflon pieces to these and whatever seal pass-through oil consumption I had has stopped.
Oh, one thing that helped me, these are a tight fit, so I also picked up an install tool, CompCams #5334, installs .500, .531 in. PTFE Seals, etc.
Re: Valve Seals [Re: dvw] #2367169
09/07/17 09:12 PM
09/07/17 09:12 PM
Doug
Doug.. I already have the 517-16 on order.. they will
be here tomorrow... do you know if the plastic sleeve
comes with the set... thanks
wave
Re: Valve Seals [Re: MR_P_BODY] #2367175
09/07/17 09:23 PM
09/07/17 09:23 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Yes, the sleeve comes with them.
Doug
Re: Valve Seals [Re: Diplomat360] #2367181
09/07/17 09:28 PM
09/07/17 09:28 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
[quote=Diplomat360]CompCams #529-16 here. They are setup for 0.530" valve guide diameter and 11/32 valve stem. Looks like the VITON seal material is "placed/formed" around core metal jacket.
[/quote}
You are correct for .530" guide 529-16 not 503-16
Doug
Re: Valve Seals [Re: MR_P_BODY] #2367217
09/07/17 10:28 PM
09/07/17 10:28 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
wave
They do purchase them. Can't say if they are in stock or not but I have an order I'm putting together for them so they could possible be added on if need be.
Re: Valve Seals [Re: dvw] #2367219
09/07/17 10:31 PM
09/07/17 10:31 PM
Thanks Doug.. I was gonna pick up one of those
tools but I dont think I will need it
wave
Re: Valve Seals [Re: MR_P_BODY] #2367222
09/07/17 10:37 PM
09/07/17 10:37 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Doug
wave
Hmmm, wonder who taught Comp Cams what they know about Viton valve stem seals.......
