Valve Seals
#2366847
09/07/17 10:30 AM
09/07/17 10:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm looking to replace my valve seals... who makes the best.. .343 (11/32 dia) thanks
Re: Valve Seals
[Re: roadhazard]
#2366978
09/07/17 02:53 PM
09/07/17 02:53 PM
MR_P_BODY
Greg.. quick question..did you ever make any W5 intake gaskets... I see you have a 6300 and the W2 ones but I think the 6300 is a stock 340/360.. is this true...thanks
Re: Valve Seals
[Re: MR_P_BODY]
#2367008
09/07/17 03:43 PM
09/07/17 03:43 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Greg.. quick question..did you ever make any W5 intake gaskets... I see you have a 6300 and the W2 ones but I think the 6300 is a stock 340/360.. is this true...thanks W-5 intake gaskets? Who in their right mind would make those? Yes, they are offered in .031" (#6310), .047" (#6311) and .062" (#6312) thicknesses, MicroPore-15 material
Re: Valve Seals
[Re: MR_P_BODY]
#2367153
09/07/17 08:15 PM
09/07/17 08:15 PM
Posts: 1,753 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
CompCams #529-16 here. They are setup for 0.530" valve guide diameter and 11/32 valve stem. Looks like the VITON seal material is "placed/formed" around core metal jacket.
These seals worked great for me, I went from the hard Teflon pieces to these and whatever seal pass-through oil consumption I had has stopped.
Oh, one thing that helped me, these are a tight fit, so I also picked up an install tool, CompCams #5334, installs .500, .531 in. PTFE Seals, etc.
Re: Valve Seals
[Re: dvw]
#2367169
09/07/17 09:12 PM
09/07/17 09:12 PM
MR_P_BODY
Mike for 11/32 stems I use Comp Cams 517-16 (.500" guide) or 503-16 (.530" guide). Easy to install, they're small outer diameter, good oil control. Doug Doug.. I already have the 517-16 on order.. they will be here tomorrow... do you know if the plastic sleeve comes with the set... thanks
Re: Valve Seals
[Re: Diplomat360]
#2367181
09/07/17 09:28 PM
09/07/17 09:28 PM
Posts: 9,813 MI, usa
dvw
MI, usa
[quote=Diplomat360]CompCams #529-16 here. They are setup for 0.530" valve guide diameter and 11/32 valve stem. Looks like the VITON seal material is "placed/formed" around core metal jacket.
[/quote} You are correct for .530" guide 529-16 not 503-16 Doug
Re: Valve Seals
[Re: MR_P_BODY]
#2367217
09/07/17 10:28 PM
09/07/17 10:28 PM
roadhazard
Akron, Ohio U.S.A.
Works for me..can I get them thru Mancini's Thanks They do purchase them. Can't say if they are in stock or not but I have an order I'm putting together for them so they could possible be added on if need be.
Re: Valve Seals
[Re: MR_P_BODY]
#2367222
09/07/17 10:37 PM
09/07/17 10:37 PM
roadhazard
Akron, Ohio U.S.A.
Mike for 11/32 stems I use Comp Cams 517-16 (.500" guide) or 503-16 (.530" guide). Easy to install, they're small outer diameter, good oil control. Doug Doug.. I already have the 517-16 on order.. they will be here tomorrow... do you know if the plastic sleeve comes with the set... thanks Hmmm, wonder who taught Comp Cams what they know about Viton valve stem seals.......
