E BODY HOOD HINGES #2366525
09/06/17 06:10 PM
09/06/17 06:10 PM
MILFORD, MICHIGAN
MILFORD MOPARS Offline OP
MILFORD, MICHIGAN
hey guys any feed back on amd hood hinges for ebodys.
hows the fit? always a gamble buying used ones.theones I have must be worn out. always stays up in the rear on closing.
thanks
Re: E BODY HOOD HINGES [Re: MILFORD MOPARS] #2366529
09/06/17 06:16 PM
09/06/17 06:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That's a common problem with E-bodes but 99% of the time it's an adjustment issue. The adjustment is backwards from what you would think. I'll wait for others to explain it better but I think the front of the hinge has to move UP in order for the back to go down.
Re: E BODY HOOD HINGES [Re: MILFORD MOPARS] #2366530
09/06/17 06:19 PM
09/06/17 06:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Re: E BODY HOOD HINGES [Re: burdar] #2366532
09/06/17 06:19 PM
09/06/17 06:19 PM
MILFORD, MICHIGAN
MILFORD, MICHIGAN
thankyou I'm going to check that.
Re: E BODY HOOD HINGES [Re: MILFORD MOPARS] #2367563
09/08/17 06:34 PM
09/08/17 06:34 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I put a brand new set of hood hinges from AMD and they fit and work great. No problems. Give Bill a call at Modern Mopar Muscle he will set you up. 844.275.9254
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: E BODY HOOD HINGES [Re: MILFORD MOPARS] #2367599
09/08/17 08:21 PM
09/08/17 08:21 PM
pawling n.y.
cudachas Offline
cudachas  Offline
pawling n.y.
Sent mine to Resto Rick, they fit and work perfect. Turn around was quick.
Re: E BODY HOOD HINGES [Re: cudachas] #2368693
09/11/17 09:29 AM
09/11/17 09:29 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
same here. keep your cash in the usa when possible
Re: E BODY HOOD HINGES [Re: MILFORD MOPARS] #2377177
09/26/17 02:26 PM
09/26/17 02:26 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I remember a difference between 70 and 71 to 74 hinges
Re: E BODY HOOD HINGES [Re: burdar] #2377193
09/26/17 02:56 PM
09/26/17 02:56 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
iagree
Most times the hinges are fine and are not adjusted correctly.
LINK Click here.
