Question on LED lights in paint booth #2366250
09/06/17 08:39 AM
09/06/17 08:39 AM
grand rapids mi. usa
P
Purestocker Offline OP
P
Changing my paint booth in my shop and the new lamps have no bulbs, these are typical 4 foot fluorescent fixtures but are set up for LED tubes, (no ballast and powered on one end) just looking for input on what lamps provide the best light for this application, thanks in advance
Re: Question on LED lights in paint booth [Re: Purestocker] #2366269
09/06/17 10:00 AM
09/06/17 10:00 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i have no LED light answer.
the lights in our 2 booths at the shop where i work at are color corrected lights. you need color corrected lights to properly see the color.
if you think you don't need color corrected lights then just buy the cheapest lights you can find.
perception is 90% of reality
Re: Question on LED lights in paint booth [Re: Purestocker] #2366326
09/06/17 12:11 PM
09/06/17 12:11 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I would have thought besides color temp, the most important light fixture aspect is an explosion proof rating or something, are these outside the booth and therefore exempt? work
Re: Question on LED lights in paint booth [Re: Purestocker] #2368278
09/10/17 01:19 PM
09/10/17 01:19 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
When buying LED lamps, look at the lumen output not the price.
Lower lumens means less light output.
A standard 4 foot T8 lamp puts out just under 3,000 lumens.
The older T12 lamp is around 2,600 lumens.
Keep that in mind when looking at the 4 foot LED replacement lamps.
If your booth had nice and bright lighting with the fluorescent lamps and you replace them with cheap LED lamps there's a good chance you're going to be disappointed.
EDIT- Some of the LED replacement lamps you can get at the big box stores are for fixtures that still have the fluorescent ballasts in them so be sure to get the lamps that are for fixtures that have been re-wired like yours.
