Re: Looking for stock hemi mufflers
[Re: 420SIX]
#2366544
09/06/17 06:36 PM
09/06/17 06:36 PM
Posts: 20,149 Park Forest, IL
slantzilla
Park Forest, IL
Call Jeff Long over in Paxton, Mark. He can probably fix you up. 217/379-4415
[Re: dogdays]
#2366657
09/06/17 10:11 PM
09/06/17 10:11 PM
RapidRobert
Dynomax 17748 or 17749 are, I believe, quite close to the Hemi factory mufflers. I believe that there is a 3" version in the Dynomax catalog. Dynomax is the performance branch of Walker. Yes, there are (2) 3" versions, one with 2&1/2" internals & one with 3" all the way thru, that is the one you want tho it is way more expensive.
[Re: 420SIX]
#2366744
09/07/17 12:53 AM
09/07/17 12:53 AM
Posts: 8,390 Highland, MI.
Sunroofcuda
Highland, MI.
The Dynomax Super Turbos are not the same as the original Chrysler mufflers internally - they flow better than the OE ones I would bet on. The correct ones for the A & B-Bodies were 20" long bodies, & offset entry / center out. These design Super Turbos flow in either direction also. Dynomax called the 17748 a "Hemi" muffler - because of the configuration. A 3" version of this is #17769. This is also a 20" long body, but a larger oval body - 5.5" x 11". The center section of the Super Turbos are wrapped with a fiberglass blanket for sound absorption, but this will break-down & dissipate fairly quickly so the mufflers will get louder over time. The 3" version will get REALLY loud - I have a buddy that has the 16" bodied ones on a 440-6 Challenger & they sounded great when the system was new, but after a couple of summers the exhaust got ridiculously loud. Car needs resonators now to be tolerable - he still has not installed any & I've offered to make some for him. The Super Turbos look like stock mufflers - they have spun-locked heads, not welded construction. They have large diameter internal flow tubes, unlike OE mufflers that downsize internally. They also have a lifetime warranty - so keep your receipt. I would use the Dynomax instead of vintage OE mufflers any day.
[Re: 420SIX]
#2367587
09/08/17 07:42 PM
09/08/17 07:42 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
I had the Dynomax 17747 (2-1/4" in / out) on my 67 Coronet and promptly took them off. At part throttle under load they sounded like a glass pack. I reinstalled the Accurate 6885 mufflers I had taken off. Much better.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
