Wing window loop bracket question #2365338
09/04/17 06:46 PM
09/04/17 06:46 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Hey guys. Both my loop brackets are broken off my wing window tracks. Is there a way to reattach them with fasteners? It looks like the window side glass needs to slide past them to retract into the window all the way.
I’m listening.
Re: Wing window loop bracket question [Re: Big Bad Bee] #2365352
09/04/17 07:12 PM
09/04/17 07:12 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Not 100% familiar with how those are attached. Is there a spot weld or plug weld that broke loose? Can you tell how were they attached to begin with?
Tony's Parts has a kit and from the picture it appears there are holes in the side of the plates. Maybe they bolt in somehow?
http://tonysparts.com/newproductsB.htm
Re: Wing window loop bracket question [Re: Neil] #2365363
09/04/17 07:31 PM
09/04/17 07:31 PM
Spokane Valley, WA
Spokane Valley, WA
They are originally spot welded from the inside of the track. What remains is a pair of holes about the diameter of. #10 screw.
I’m listening.
Re: Wing window loop bracket question [Re: Big Bad Bee] #2365364
09/04/17 07:35 PM
09/04/17 07:35 PM
Mass
charge70 Offline
charge70  Offline
Mass
Just weld them back on.Thats what I did with mine.I put small welds on the sides and your done.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Wing window loop bracket question [Re: charge70] #2365369
09/04/17 07:45 PM
09/04/17 07:45 PM
Spokane Valley, WA
Spokane Valley, WA
wish i could. I have no welder. don't know any welders. it's Labor Day... I'm looking for another solution. Thanks though.
I’m listening.
Re: Wing window loop bracket question [Re: Big Bad Bee] #2368753
09/11/17 11:53 AM
09/11/17 11:53 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
Hi,
we supply shallow head screws with ours to attach them
Re: Wing window loop bracket question [Re: Big Bad Bee] #2369513
09/12/17 05:07 PM
09/12/17 05:07 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Talk to Ralph . . . he could fix those up at his place in 5 minutes !!! I had same thing on 70 Sport Satellite . . . I welded them back together myself . .. .
