Wing window loop bracket question
#2365338
09/04/17 06:46 PM
09/04/17 06:46 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Hey guys. Both my loop brackets are broken off my wing window tracks. Is there a way to reattach them with fasteners? It looks like the window side glass needs to slide past them to retract into the window all the way.
I’m listening.
Re: Wing window loop bracket question
[Re: Big Bad Bee]
#2365352
09/04/17 07:12 PM
09/04/17 07:12 PM
Posts: 20,777 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Not 100% familiar with how those are attached. Is there a spot weld or plug weld that broke loose? Can you tell how were they attached to begin with? Tony's Parts has a kit and from the picture it appears there are holes in the side of the plates. Maybe they bolt in somehow? http://tonysparts.com/newproductsB.htm
[Re: Neil]
#2365363
09/04/17 07:31 PM
09/04/17 07:31 PM
Big Bad Bee
Spokane Valley, WA
Not 100% familiar with how those are attached. Is there a spot weld or plug weld that broke loose? Can you tell how were they attached to begin with? Tony's Parts has a kit and from the picture it appears there are holes in the side of the plates. Maybe they bolt in somehow? http://tonysparts.com/newproductsB.htm They are originally spot welded from the inside of the track. What remains is a pair of holes about the diameter of. #10 screw.
I’m listening.
[Re: Big Bad Bee]
#2365364
09/04/17 07:35 PM
09/04/17 07:35 PM
Posts: 603 Mass
charge70
Mass
Just weld them back on.Thats what I did with mine.I put small welds on the sides and your done.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2365369
09/04/17 07:45 PM
09/04/17 07:45 PM
Big Bad Bee
Spokane Valley, WA
Just weld them back on.Thats what I did with mine.I put small welds on the sides and your done. wish i could. I have no welder. don't know any welders. it's Labor Day... I'm looking for another solution. Thanks though.
I’m listening.
