T Quad guroos #236363
02/25/09 08:57 PM
02/25/09 08:57 PM
Finally a HUSKER again
Moparnut426 Offline OP
Who is the T Quad masters on here? I have one needing some help for my ol powerwagon.
Kasey
Re: T Quad guroos [Re: Moparnut426] #236364
02/25/09 09:02 PM
02/25/09 09:02 PM
Kalispell Mt.
HotRodDave Offline
Happy Birthday HotRodDave  Offline
Kalispell Mt.
I know them pretty well, DemonSizzler problably knows them better. What you got?
Re: T Quad guroos [Re: HotRodDave] #236365
02/25/09 09:05 PM
02/25/09 09:05 PM
Its a low mile carb off a 440 in a motor home, but Im trying to down jet it for the 360 in my truck. Mancinni said they couldnt help me.
Re: T Quad guroos [Re: Moparnut426] #236366
02/25/09 10:07 PM
02/25/09 10:07 PM
Kalispell Mt.
HotRodDave Offline
Kalispell Mt.
I have (had) one on my 68 318 cuda from a 74 440 and just a little tuneing made it run good, no jet or rod changes. It got 29 mpg one time so it is not running too rich. I would try it as is and report back any running problems.
Re: T Quad guroos [Re: Moparnut426] #236367
02/25/09 10:18 PM
02/25/09 10:18 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Jet-it-down ? ... not necessary !! ... just RAISE the tree if it is a touch rich.
Re: T Quad guroos [Re: dOc !] #236368
02/26/09 03:43 AM
02/26/09 03:43 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Dont you mean lower the tree? If you lower the tree, that will put the metering rod deeper in to the jet, making it leaner.
Re: T Quad guroos [Re: formula S] #236369
02/26/09 04:35 AM
02/26/09 04:35 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Ooooops ....brain fade ...I stand corrected.
Re: T Quad guroos [Re: Moparnut426] #236370
02/26/09 09:49 PM
02/26/09 09:49 PM
Stone Mt, GA.
DEMONSIZZLER Offline
super gas
super gas
Stone Mt, GA.
As alluded to above, you don't need to re-jet unless the carb is a post '74 passenger car T.Q. with smogger calibration. All '71-'74 T.Q.'s can be run as-is without re-jetting. The engine will only use the exact air and gas it needs thanks to the sophistication of these carbs. All three main circuits, idle, cruse and wot(hi speed)can be 'dialed-in' externally to compensate for weather and atmospheric conditions etc. So you can easily tune for max performance and gas mileage, David.
By the way, this pic confirms the flexibility of a Thermoquad!
